console liner install
Old Apr 24, 2022 | 10:48 PM
CleanCutt's Avatar
what the easiest way to put the liners in and hooking the light switch up?thanks
Old Apr 25, 2022 | 06:18 AM
BackInTheGame's Avatar
What year and model?
Old Apr 25, 2022 | 10:46 AM
CleanCutt's Avatar
sorry forgot to say its a 71 cutlass supreme convetible
Old Apr 25, 2022 | 12:54 PM
Feed the switch wires up through the hole in the rear of the console.
Put the front of the inserts into the console well, then feed the wires through the hole in the insert.
Install the screws in the base of the inserts.
For installing the light switch, I connect the wires to the switch spade terminals, then spin the switch to wind the wires several turns. Insert the switch into the hole, and screw it into place. The wires unwind as the switch is screwed in.
Old Apr 25, 2022 | 11:28 PM
CleanCutt's Avatar
Thanks ill try that
RandyS
Feb 1, 2021 03:27 AM
Michael Tolomei
May 15, 2018 07:18 AM
Redbud40
Jul 17, 2014 05:59 PM
Al Sanchez
Jun 4, 2013 02:59 PM
Al Graaf
Jun 28, 2012 05:01 PM
