column to floor swap in 65 J88
Old Nov 1, 2020 | 06:48 PM
tlrche67's Avatar
I want to swap the column shifter to the floor.
Any particular model center console that would work?
Old Nov 2, 2020 | 05:05 AM
J88s used the same console as was used in the 64-68 Cutlass line. This shifter uses a rod, not a cable. That makes the location in the car important to ensure you can access all the gears in the trans. You'll likely need to fabricate custom mounting brackets since no one repros the brackets for the full size cars.
Ronniev
Oct 8, 2019 09:36 AM
luap383
Oct 23, 2015 01:01 PM
shamusj
Mar 15, 2015 09:30 AM
HiCompOlds
Jan 10, 2013 09:02 AM
rlang
Nov 7, 2009 01:52 PM
