Cheap Sunvisor Fix
Old Aug 8, 2010 | 01:49 PM
Higgins's Avatar
Cheap Sunvisor Fix
I was having trouble with my sun visors staying up, both have mirrors so they are heavy & the rubber tips were dry rotted. I know they do make the new rubber tips but I thought there might be another method. I was in the hardware store & saw a package of assorted rubber tips for the spring type home door-stops for $1.00. I took out the 2 smallest ones, they were a bit big in diameter, inside & outside. Well, I had a piece of small tubing that is used for intravenous injections. This small tubing fit on the visor end perfect & inside the door-stop tip perfectly. Now I had to make the tip fit into the bracket, so I trimmed it smaller on the outside with a utility knife, then sanded it with 100 grit wrapped on a paint stick to get rid of the knife marks, make it round and just rough enough for friction to hold the viors in place. I now have sunvisors that stay put going over bumps. My visors & headliner are white & so are the door stop rubbers, a magic marker could be used to change the color if needed.
I like to pass along fixes that I come up with and hope someone else can benifit.
Old Aug 9, 2010 | 05:35 AM
Lady72nRob71's Avatar
Neat idea!
In this hobby, we often have to resort to creative engineering...
Old Aug 9, 2010 | 06:33 AM
Bluevista's Avatar
Registered
You could of just duct taped the visors to the headliner.
My grandpa would have used chewing gum and bailing wire.
Old Aug 9, 2010 | 06:42 AM
I have actually used gum to hold a bolt to an aluminum strip so I could get it into a hole deep in the quarter window reg, through the door pillar vent...
Old Aug 9, 2010 | 11:11 AM
Higgins's Avatar
Duct tape & WD-40, the only tools you ever need. If it moves and it's not suppose to, use duct tape. If it i suppose to move and it doesn't, use wd-40.
Old Aug 9, 2010 | 11:21 AM
Oldsguy's Avatar
Past Administrator
Good fix.
Old Aug 9, 2010 | 11:36 AM
Good fix!
Old Aug 9, 2010 | 03:44 PM
TripDeuces's Avatar
Higgins you forgot the Ballpeen hammer
Old Aug 9, 2010 | 05:18 PM
66ninetyeightls's Avatar
Land Yacht Captain
Duct tape fixes everything. Even a Honda!!!
auto_editor
Jul 9, 2015 07:34 AM
50srocker
Sep 18, 2011 12:24 PM
OldsManNJ
Jun 2, 2011 05:11 PM
Aceshigh
Apr 14, 2010 04:57 AM
56TuTone88
Dec 28, 2006 02:59 PM
