Bucket Seat Tract Bolt Size 1972 CS
Old Dec 16, 2018 | 06:30 AM
travisbeamon's Avatar
Good morning,
What is the correct bolt size to mount the bucket seat tract to the floorboard for a 1972 Cutlass Supreme. I saw kits online but I’d rather purchase local if possible. Thank you.
Old Dec 16, 2018 | 07:16 PM
70Post's Avatar
5/16" x 1" for the bolts. Pic shows an original (at the bottom) and a replacement. Both have captive flat washers on them and the washers have small "spikes" on the underside to help keep things locked down once tightened. You may be able to use a thick flat washer with no "spikes".....it helps spread the load out over the foot of the seat track.
Old Dec 17, 2018 | 07:46 AM
oddball's Avatar
Hardware bolts work just fine. I use flange washer head bolts for those two positions and pinch nuts for the studs.
Old Dec 17, 2018 | 07:53 AM
They do, but be sure to get Grade 8.
Old Dec 17, 2018 | 05:19 PM
Thank you both so much!
RWB
Mar 19, 2018 04:06 PM
Jay D
Sep 23, 2017 04:30 PM
Al Graaf
Apr 16, 2013 06:36 PM
yeahbuddy
Mar 28, 2011 10:39 PM
Driftr
Oct 26, 2009 08:59 PM
