Help with seat extenders!
Old Apr 13, 2013 | 01:54 PM
Al Graaf's Avatar
Formerly "Shimmer"
Just bought seat extender for my 71 442. Says bolts to seat and track bolts to floor. I've tried and tried to figure this one out. Got em from PP. Any advise? PP# in10503z- Rebuilt the car and this is whipping my a--.
Thanks guys!
AL
Old Apr 14, 2013 | 07:35 PM
starfire's Avatar
Looks like your original studs go in the holes (there are two on one end as I think the studs front to back are offset so having two holes makes each part universal) and then your seat bolts to the studs that are in the bracket.
I got the ones from Year One for the '49 and they worked slick. The only problem I ran into was the original bolts ('49's did not have studs with nuts) were too short. Quick trip to the hardware store solved that. The Year One design is one plate for each seat foot.
Old Apr 15, 2013 | 02:57 PM
Al Graaf's Avatar
Formerly "Shimmer"
Thanks for the input. So these brackets bolt to the floor and the the seat to them?
AL
Old Apr 15, 2013 | 04:20 PM
starfire's Avatar
AL
Yes.
Old Apr 15, 2013 | 05:28 PM
olds style's Avatar
For some reason the application chart starts with 1966. Not sure why they wouldn't work on 64-65 A body.....anyone?
Old Apr 16, 2013 | 03:43 AM
Al Graaf's Avatar
Formerly "Shimmer"
Yes.
Boy that sure is going to look ugly!
Old Apr 16, 2013 | 03:45 AM
starfire's Avatar
Maybe they go under the carpet? You'd have to poke new holes in the carpet for the studs.
Old Apr 16, 2013 | 03:52 AM
Al Graaf's Avatar
Formerly "Shimmer"
That's a thought. Makes sense. What a bitch....
AL
Old Apr 16, 2013 | 05:02 AM
starfire's Avatar
Hells bells Al, I just looked at the Parts Place ad again. It does look like you have to take your seat tracks off, then bolt those to the bottom of the seat, then the studs that are on the brackets are used to bolt your tracks back on. What a PITA. The ones I got from Year One worked much easier imo.
Old Apr 16, 2013 | 06:23 AM
Al Graaf's Avatar
Formerly "Shimmer"
Allan,
Do you have their part #. Tried to look up but....you can send to me at
Resimprove@aol.com That's what I thought!
AL
Old Apr 16, 2013 | 07:00 AM
olds style's Avatar
pp...$79
yo....$109
If your right about the different mounting instructions, than the PP ones might leave more headroom....
Thoughts on that...???
Old Apr 16, 2013 | 12:55 PM
Al Graaf's Avatar
Formerly "Shimmer"
Originally Posted by olds style
pp...$79
yo....$109
just spoke with YO. Part # sb246 makes sense and $39! Check the pictures on their site.
Al
Old Apr 16, 2013 | 12:57 PM
Al Graaf's Avatar
Formerly "Shimmer"
Just checked YO sb246-seems the way to go. If I'd known when I was restoring the car I would have moved the brackets back. But hind site 20/20
Old Apr 16, 2013 | 02:15 PM
starfire's Avatar
Al
Yup, them's the ones I got for the '49. They worked real nice, now the steering wheel isn't in my chest anymore and my legs are at a more comfortable angle.
Old Apr 16, 2013 | 02:45 PM
fitter bill's Avatar
i just finished installing my own extenders , went to Lowes picked up some 1/8 x 3 flat stock measured the holes in floor & drilled em into the stock measured the holes in seat mounts set the holes back 2" on the flat stock & drilled them . ran bolts through holes brazed bolt heads to the underside of stock & mounted to the floor under the carpet ( need to make new holes in carpet ) mounted the seat works great. BILL
Old Apr 16, 2013 | 06:32 PM
Al Graaf's Avatar
Formerly "Shimmer"
So now you tell us!Great idea!
AL
Old Apr 16, 2013 | 06:36 PM
Al Graaf's Avatar
Formerly "Shimmer"
Good nuff for me. Ordering in the AM. Thanks for all your input!
nelsontj
Sep 19, 2012 09:33 PM
68Tom
May 8, 2012 07:41 PM
68Tom
Sep 16, 2010 10:41 AM
ctrain22
Aug 15, 2010 08:46 PM
dc2x4drvr
Oct 19, 2009 04:20 PM
