Assembly Manual /door panels
Am I missing pages or does the 1970 cutlass manual NOT diagram door panel install?
I just want to know where the window guides would be placed( mine are missing) , the bolt size for the window stop(missing) and the simple order of panel, spring,washer and window crank.
I’m replacing both panels and all rests and hardware , along with the outside window weather stripping. Ive searched here and googled but no help. Thanks for any info !
1970 Fisher Body Service Manual. I believe it's in Section 6.
EDIT: I found an on-line version for 1971 Fisher Body Service Manual - Doors section. I've seen some other years available on-line, as well. I own a .PDF 1971 Fisher Body Service Manual. I don't own the paperback edition. The problem with the .PDF and most digital versions is the poor quality of the diagrams/illustrations - each diagram/illustration (including mine) is very dark and nearly illegible. If you want the best illustrations/diagrams I suggest you purchase the paperback edition. The link below will at least provide you with an overview of what's contained in the Fisher Body Service Manuals. There are many paperback editions available for purchase on-line. GL
http://www.tseafoamo.com/Manuals/1971Fish.pdf
