Alero door panel
Old July 11th, 2009, 03:55 AM
Yellowstatue's Avatar
Angry Alero door panel
How do I get the door panel off a 2001 Alero?? I removed the screws near the door handle and don't see anything else to remove...I don't want to damage this thing....and I don't want to cut the skin off the outside...
Yellowstatue is offline
Old July 11th, 2009, 07:02 PM
Redog's Avatar
There is a screw behind the reflector also. Then pull out on the bottom and the sides of the panel, there are some body plugs in there. After the plugs are out, push up on the bottom of the panel, Have the window down first.
Remove the tweeter before you do this. It flys out and could break the tabs in the process
Redog is offline
Old July 13th, 2009, 10:04 PM
Smile Eternally greatful
Thanks Redog; I don't have a lot of experience fixing new cars!! This should happen after we get back from PA...
Old August 29th, 2009, 03:26 AM
Thanks again redog...took off the passenger panel and found that the remote rods are too thin to hold their shape...re-bent one bend and found also that the rod close to the handle was rubbing on the inner metal panel...so I twisted the rod to get clearance and that let the handle return to it's proper place...now it works properly, also sprayed a lot of lubricant around the latch mechanism and it feels smoother now...
onofre442
December 1st, 2013 10:36 AM
rsylvstr
July 5th, 2010 02:35 PM
Steve O
December 12th, 2008 01:03 PM
coldfire
Alero
December 29th, 2006 01:59 AM
ventport
Alero
November 5th, 2006 04:17 PM
Quick Reply: Alero door panel
