AC Controls Question
Old Dec 5, 2020 | 08:59 AM
Hello, question regarding AC controls on 72 Olds A body.
Background: I'm used to a 72 Chevy with the first picture's controls. When not using the system, I typically leave it on (mode) VENT and (fan) OFF. This allows some flow through ventilation. Turning the mode to OFF as well stops any flow through ventilation, and I rarely do it. I think it would kill fan power too were it to be on something other than off. It has a 5 position switch for a 4 speed fan and off. So, it allows vent and no fan.
The non-AC controls in the third picture have a 4 position switch for a 3 speed fan and off. This would allow vent and no fan.
The AC controls in the second picture have a 4 position switch for a 4 speed fan and no off. I think the blower is on in whatever speed is set when ignition on and the system is anything other than OFF. So I do not think vent and no fan is possible on my 72 H/O with AC.
Am I correct in that assumption? Thank you.
Old Dec 5, 2020 | 09:10 AM
You are correct, that is the way the factory system works. Slide the lever to OFF and there is no air flow, either fan or flow-through.
Old Dec 5, 2020 | 02:49 PM
Thanks. I figured our man in AZ knows the AC.
If it were my daily driver, I'd do something about it, but it is ok this way. Plus, I am going to do my granddad's routine of getting a vent windowed non AC car's black kick panel with one vent pull for the driver's side so I can have a vent for me. (Right side gets no change as AC mix door is there.)
jpfiff68@gmail.com
Dec 29, 2021 05:38 AM
dddddyang
Oct 10, 2017 10:57 AM
Stephen0523
Jul 22, 2017 05:04 AM
HammerVette
Mar 26, 2014 07:34 PM
VikingBlue
Jul 10, 2012 08:58 AM
