72 Cutlass dash/radio fix?
Old Oct 20, 2015 | 12:15 PM
jlauffer's Avatar
My 72 Cutlass came with an ugly aftermarket DIN type radio, and would like to replace it with a modern old-style unit (like Custom AutoSound or similar). The problem of course is that they cut the dash to install the current unit...there is a single large rectangular hole instead of the smaller center rectangle with a circular hole on each side. Is there some sort of insert/bracket available that can be installed so that the older shaft-syle radio can be installed? I figured if I replaced the woodgrain trim insert once it's all done it would cover it all up and still look decent.
Old Oct 20, 2015 | 12:23 PM
Tom442's Avatar
Maybe?
Use one of these and then your woodgrain trim?
http://www.classiccarstereos.com/cat...IN-Radios.html
Old Oct 20, 2015 | 12:52 PM
jlauffer's Avatar
I suppose another DIN style could work, but one of the issues with the current one is that it sticks out of the dash quite a ways and has a big black trim/adaptor piece that just makes it look like crap. If it could be more flush and "clean" then I might be able to accept it. But ideally I'd like to go back to a more stock appearance. At some point I'll pull the current one out and see what I have to work with. If I can get a suitable piece of metal I might be able to fab something up myself to allow the older style radio to be installed. But if something was already available that would be a lot easier.
Old Oct 20, 2015 | 02:54 PM
My442's Avatar
The best way to swap out the lower dash.
auto_editor
Jul 9, 2015 07:34 AM
Octania
Jul 1, 2013 09:47 AM
dancutlass
Oct 2, 2012 02:49 AM
sx455raidercelticfan
Jul 29, 2010 07:44 PM
yeahbuddy
Mar 5, 2010 08:57 AM
