71 Convertible rear seat courtesy lights
Old Jun 22, 2022 | 08:01 AM
JVCCutlass's Avatar
Does anyone know of the lens on the rear seat courtesy lights just pry out or is it necessary to remove the rear seat and the side panel to get to the bulb to replace it ?
Old Jun 22, 2022 | 08:44 AM
stlbluesbrother's Avatar
I recently swapped out the bulbs and had to remove the seat and side panel as the receptacle seemed to clamp on the bulb disallowing it to be pulled out from the front. That said, I would first try to access and remove the bulbs while the interior is in place.
The lenses have 4 tiny tabs stabilizing them in the bezel. 2 on top and 2 on bottom. If they are not brittle from age, the lenses can be pried out by applying light pressure near the tabs. Once out you probably know the drill of pushing the bulb inward and turning to release it.
Old Jun 28, 2022 | 09:55 AM
JVCCutlass's Avatar
Thanks - the lens came out really easily.
The bulb I took out was a #68 , not easily found , Can another bulb be used for the rear seat courtesy light ?
jvcCutlass
Old Jun 28, 2022 | 02:26 PM
tnswt's Avatar
'70 4-Speed W Machine
Wagner #68 Bulb can be found:
At Rock Auto:
https://www.rockauto.com/en/moreinfo...319135&jsn=981
At Amazon:
Amazon Amazon
Old Jun 28, 2022 | 10:10 PM
I would check your local NAPA store.
Old Jun 30, 2022 | 06:04 AM
jvcCutlass
Going from memory, but I believe the correct bulb is the #90 per the Chassis manual. I recently bought a 2 pack from 0'Reilly Auto Parts for around $6.
JVCCutlass
Jun 18, 2018 06:41 AM
nwcajun
Feb 16, 2018 08:14 PM
stevengerard
Sep 17, 2016 08:08 AM
Kevin2
Jun 23, 2012 05:12 PM
