71 Convertible rear seat courtesy lights
Does anyone know of the lens on the rear seat courtesy lights just pry out or is it necessary to remove the rear seat and the side panel to get to the bulb to replace it ?
The lenses have 4 tiny tabs stabilizing them in the bezel. 2 on top and 2 on bottom. If they are not brittle from age, the lenses can be pried out by applying light pressure near the tabs. Once out you probably know the drill of pushing the bulb inward and turning to release it.
Wagner #68 Bulb can be found:
At Rock Auto:
https://www.rockauto.com/en/moreinfo...319135&jsn=981
At Amazon:
At Rock Auto:
At Amazon:
Going from memory, but I believe the correct bulb is the #90 per the Chassis manual. I recently bought a 2 pack from 0'Reilly Auto Parts for around $6.
drjimz
Ninety-Eight
Apr 2, 2019 08:32 AM
JVCCutlass
Jun 18, 2018 06:41 AM
