69 dash help
Old Jun 22, 2021 | 07:15 PM
brotherGood's Avatar
69 dash help
I've got 2 more things to do (so far that I'm aware of) with the dash in my 69 442..
1. Change the light bulb for the radio. My question with this is simply, how? I've not seen where the bulb is..do I need to pull the glove box and/or dash out?
2. The light/dimmer switch is pretty intermittent. I went ahead and ordered a new one...what is the best way to switch those out?
Thanks.
Old Jun 23, 2021 | 05:24 AM
The radio bulb is in the holder at the end of the white wire under the tape in this photo. That metal holder pries out of the housing and will have the bulb in in.
There's only one way to remove the headlight switch. Remove the ****, unscrew the bezel, and pull the switch out from behind the dash. You need to pull the **** out to the headlights on position, then press and hold the spring loaded button while pulling the **** the rest of the way out. Yeah, you have to contort your arm up under the dash to do that.
Old Jun 23, 2021 | 06:51 AM
Do I need to remove the radio in order to change the bulb, or is there plenty of room to get my hand up in there?
Old Jun 23, 2021 | 08:08 AM
rcorrigan5's Avatar
Randy C.
Just for the sake of ease and being able to see what you are doing, I would remove the radio to change the light bulb. A contortionist might be able to pull it off, but it's not that difficult to remove the radio and do it the easy way.
Randy C.
Old Jun 23, 2021 | 09:21 AM
69 Hurst's Avatar
Olds Fanatic
Randy C.
Agreed, pull the radio.
Old Jun 23, 2021 | 10:43 AM
tru-blue 442's Avatar
Old School Olds
[I went ahead and ordered a new one...what is the best way to switch those out?
Thanks.[/QUOTE]
Get your wife to do it.
Old Jun 23, 2021 | 11:50 AM
Thanks.
Get your wife to do it. [/QUOTE]
Sounds like an excellent idea 🤣
Texasbilly1964
Feb 27, 2017 07:17 PM
442nut
Mar 12, 2014 08:10 AM
dnmfranco
Jun 4, 2013 08:50 AM
derek nesdoly
Jun 12, 2009 03:00 AM
jonstringer
Mar 13, 2009 07:00 AM
