69 442 dash courtesy light
Old Apr 12, 2009 | 04:59 AM
derek nesdoly's Avatar
olds..older..oldest
Restoring my 442 and found the dash courtesy light burned[? by someone using wrong type bulb.]This is a 1" x 5" opaque plastic with black surround,black switch and white and orange 1' wire going to black 1" snap in plug. Can't find at Fusicks etc. Any ideas where to find a replacement?Thanks, derek
Old Apr 12, 2009 | 02:16 PM
My442's Avatar
I believe it is a 211 bulb.
Old Apr 12, 2009 | 02:57 PM
olds..older..oldest
Thanks, Sorry, I have the right bulb, but need the whole unit as described as the plastic has burned through. Derek
Old Apr 12, 2009 | 06:52 PM
rcorrigan5's Avatar
Randy C.
I'm not 100 percent sure, but I believe the burnt opaque lense is fairly normal. I have a '68 442 and a '69 442 and both of the lenses in them have that burnt spot where it's closest to the bulb. I don't know of anyone that has or reproduces this item.
Old Apr 12, 2009 | 07:27 PM
olds..older..oldest
Well, if that's the case, I'll just carry on and drive with my scorched lens like a badge of honour! derek
Old Apr 12, 2009 | 09:53 PM
Yellowstatue's Avatar
Smile Bright light
I surmise that you are talking about the light over the radio, if you call it a 'map light' you will have a more favourable response in your seach to ward off the night...
Old Apr 13, 2009 | 04:51 AM
My442's Avatar
Question
Post a picture of what you need.
Old Jun 5, 2009 | 02:12 PM
Jon69's Avatar
I know what your talking about. Mine is burnt also, and I've had no joy finding a replacement. I'll try to get a pic and post it.
Old Jun 5, 2009 | 02:36 PM
First, don't get your hopes up. Second, I think the map light you're looking for is the same one that fits the 70-72 cutlass. At least it sure looks like it to me from the pic you put in your thread. Take a look at the attached pic. The light is as you described for dimensions and wiring. If its what you need, you bet theres a whole lot of them out there. Used and New. I've seen these go on ebay new in box OEM NOS part for as little as 10 bucks. If you take it out of the dash does it look like the pic I just added?
Check it out and LMK>
Old Jun 6, 2009 | 03:37 AM
Smile Hot tamale
If anyone finds an LED replacement for that 211 bulb let us know...it will cut down on the heat damage!!!
Old Jun 7, 2009 | 03:53 PM
olds..older..oldest
That is indeed the varmint of which I spoke Al ! And they say there's nothing but dumb,garlic chewing Uke's out there in Alberta [ I can say that,cause I are one!] Thanx again Derek...'69 442 post-coupe
Old Jun 8, 2009 | 07:01 AM
Jon69's Avatar
Like this?
http://www.superbrightleds.com/specs/RL4410-xHP9.htm
Old Jun 11, 2009 | 08:43 PM
Jon69's Avatar
I puchased one of those LED bulbs. It works, sorta.
It's off rotation 90deg but it sets in tight enough with tension that I think it will be ok.
I don't think it's bright enough. I'm gonna keep looking for a different solution but for now it works, and wont burn up the lens any more.
Old Jun 12, 2009 | 03:00 AM
Lightbulb Night light
Thanks for that link I think map lights are going to become extinct now that everyone is using GPS...I saw one on a 1915 F**d at the Barrie cruise last Sat...I also see a lot of them on the 401 around Toronto...they are all driving around causing congestion just to see if the darn things work or they are deliberatly trying to get lost..
1969camaross350
Apr 11, 2015 11:03 PM
Aussie442
Jul 7, 2014 12:17 AM
NINETY_EIGHT_REGENCY
May 18, 2014 07:12 PM
dingusboy
May 26, 2012 10:03 AM
Denm33
May 28, 2008 07:35 PM
