69 Cutlass Glove Box Lock?
Old Mar 5, 2020 | 01:16 PM
Phoenix8990's Avatar
I have read some posts that mention that a 69 should have a push button type lock. Is that correct and if so who has them? I don't see any shown in catalogs. My lock and catch have been changed and I have a turn type of lock that is loose and spins some. I do not have a correct key for it and wonder if I can still get it out? A bent up piece of hanger wire was used for the catch. I located the correct one for a 69 and it is a plastic wedge which in no way appears to work with the current lock. Any help is appreciated.
Steve W.
Old Mar 5, 2020 | 05:28 PM
JohnnyBs68S's Avatar
I'm pretty sure the '69s are the same as the '68s which is a push button, which has a "fin" that latches on the plastic wedge type striker and retracts to release the door when the button is pressed.. It appears someone swapped your lock/latch in the door w/ a unit from a '70-'72 which are twist *****, and from the photo you provided appears to latch to a bar type striker, not a plastic wedge like in your first photo.
Old Mar 5, 2020 | 05:29 PM
Yellowstatue's Avatar
The plastic piece is correct and the latch is wrong. The latch should have a pop up spring loaded hook to catch the plastic part.
Old Mar 6, 2020 | 11:18 AM
69442murph's Avatar
This is the correct glove box lock. I have an extra if I can help. PM me.
GCH
Jun 7, 2019 05:01 AM
Bfg
Oct 17, 2015 05:54 AM
spate51
Mar 16, 2012 01:56 PM
Beob
Oct 18, 2011 06:44 PM
Kennedy6949
Ninety-Eight
Sep 28, 2010 06:07 PM
