4-Way PW Switch Clean Up Questiom ???
Old Sep 15, 2015 | 12:21 PM
pfergy600's Avatar
From: 25 miles North of Tampa, Land O' Lakes, Florida (Originally from Bethpage, Long Island, NY)
This is an original four-way power window switch and I was wondering if there is a process I can do to clean it up and remove scratches and bring a shine to it again?
Old Sep 15, 2015 | 06:08 PM
Lady72nRob71's Avatar
Aside from having it rechromed (and since it is potmetal, I am not sure if that is easily possible or worth it), you can disassemble it and use some chrome polishes on it to help subdue the scratches. A felt wheel on a dremel will be a big help. Any pitting is there to stay unless it can be rechromed.
Here is some info on the process, but I did not get aggressive with polishing...
https://classicoldsmobile.com/forums...-switches.html
And as a FYI, I did this procedure 5 years ago and the switch still looks and functions great!
Old Sep 15, 2015 | 06:39 PM
pfergy600's Avatar
Ty
Thank you Rob for the information, that was very informative. I got a wiring harness from a 1972 Pontiac Grand Prix. I will have to splice the new four-way switch on to the harness. I'm wondering if the best method would be soldering and then shrinkwrap, rather then but connectors. I have the motors all apart cleaned them out put new grease and they run like a charm. I drilled out the new holes for the power window regulators, and getting ready to install soon.
Old Sep 15, 2015 | 06:44 PM
pfergy600's Avatar
Pics
Don't know why I can only post one photo on each message from my cell..
Old Sep 15, 2015 | 06:48 PM
pfergy600's Avatar
See if this works...
Old Sep 16, 2015 | 06:21 PM
Originally Posted by pfergy600
Thank you Rob for the information, that was very informative. I got a wiring harness from a 1972 Pontiac Grand Prix. I will have to splice the new four-way switch on to the harness. I'm wondering if the best method would be soldering and then shrinkwrap, rather then butt connectors.
No problem; glad I could help.
I would certainly use solder and heat shrink tubing, as you only want to do this once. Crimp connectors can fail in a few years or sooner due to oxidation caused by moisture and dirt. The inside of a door can get pretty moist and dirty, too!
Old Sep 16, 2015 | 06:38 PM
oldspackrat's Avatar
X2 on the solder & shrink wrap. Do it once & do it right. You won't be sorry.
Old Sep 8, 2016 | 11:50 AM
pfergy600's Avatar
Need a 4 Way Power Window Connector (72 Cutlass)
I'm looking for a 4 Way power window connector like the one in the bottom of this photo for a 72 Cutlass. Does anyone know if these can be bought new, if not if any members have one they would like to sell please message me.
Thanks, Patrick
DownBoy
Aug 20, 2014 08:53 PM
odddoylerules
Dec 27, 2013 10:31 AM
Nasty455
Apr 9, 2012 11:06 AM
Vistabrat72
Feb 25, 2012 01:04 PM
bobb
Oct 4, 2010 06:02 AM
