1973 Cutlass — How do I remove the radio?
Old Mar 6, 2021 | 09:25 AM
Tfitz's Avatar
1973, not 1963. I am trying to replace my factory AM unit with another factory AM-FM unit, but I’ve been looking everywhere in here for screws or nuts to get this radio out, and can’t find anything. I have the ***** off and that’s it. This has me stumped.
Can anyone walk me through the radio removal process?
Old Mar 6, 2021 | 07:45 PM
cjsdad's Avatar
You should have 5/8 in. shaft nuts behind the ***** that hold the radio to the dash. There should also be a rear support brace that is attached to the side or rear of the radio and the u-channel of the dash with either a 5/16 or 9/32 screw.
Unplug the antenna, unplug the power and speaker plugs. Unbolt the support brace. Remove the shaft nuts. Gently remove the radio from the back side of the dash. Reverse the process to re-install the new radio.
Old Mar 6, 2021 | 07:58 PM
jaunty75's Avatar
Here's the radio removal instructions and accompanying diagram from the 1973 Olds Chassis Service Manual.
Old Mar 7, 2021 | 06:01 AM
I edited the title for you.
TomT
Jul 4, 2017 06:28 PM
Activate
Feb 2, 2014 01:06 PM
Finn5033
May 24, 2012 09:36 AM
KRICHEN922
Jul 1, 2010 09:17 AM
chuckcal
Oct 15, 2007 10:00 AM
