1970 dual gate center console
Remove the console liner inserts and you will be a able to see a couple screws for the rear attaching points.
The inserts are held in by 3 or 4 screws along the centerline and the plunger switch for the light at the rear.
1970 dual gate console
thanks for your help,had to repair indicator lamp wiring. repair complete, console back together,the only thing i need to complete the job is dual gate panel missing rocket insignia. (i know no biggy).cant seem to find just the insignia alone ,without having to buy whole panel at opgi and fusick. any ideas?
http://realoldspower.prophpbb.com/po...0emblem#p93841
Apparently Fusick sells an emblem for 69 442 door panels that will work.
http://www.fusickautomotiveproducts....?number=SE69DP
It's black instead of red though.
ah64pilot
May 29th, 2012 03:04 AM
pcard
April 4th, 2012 07:36 AM
