1968 Oldsmobile Cutlass S Glove Box Lock Position
Old Oct 16, 2020 | 08:29 PM
jdana24's Avatar
1968 Olds Cutlass S
I have a question I want to run by the experts regarding the glove box lock on my 1968 Oldsmobile Cutlass S. The lock on my car has always been a little loose, and lately, it just spins since the escutcheon isn’t tight to the **** assembly. In the below photo, the position of the lock is at 9:00, and I’m wondering is that in the locked or unlocked position. I want to make sure mine is correct when I put the lock back into position.
​​​​​​Also, since I took the lock out, I thought I would clean the lock/tumblers and lubricate them before I put them back on the glove box door. What would you recommend I use to clean the tumblers? And what should I use to lube them?
Old Oct 16, 2020 | 10:10 PM
Yellowstatue's Avatar
3:00 is unlocked, 12:00 is locked. |Your lock is at 3:00. Graphite is recommended for lock cylinders, nothing sticky that will attract and hold dust.
Old Oct 17, 2020 | 12:06 AM
jdana24's Avatar
1968 Olds Cutlass S
So just to clarify, are you saying my lock is currently in the 3:00 position. The way I look at it is the open end of the lock is at 9:00. Are you saying I need to turn it clockwise 180 degrees so the open end of the lock is at 3:00? Below is a close-up of the lock. The way I was describing it in the initial post was the open end is at 9:00 in this photo.
Old Oct 17, 2020 | 02:12 PM
The lock in the picture is open, turn it CCW to lock.
Old Oct 18, 2020 | 06:34 PM
jdana24's Avatar
1968 Olds Cutlass S
OK, thanks for clarifying for me Yellowstatue.
1965Oldsmobile
Apr 25, 2023 02:07 PM
matt69olds
Oct 13, 2020 08:22 AM
GCH
Jun 7, 2019 05:01 AM
chip-powell
Feb 4, 2016 01:39 PM
Bfg
Oct 17, 2015 05:54 AM
