1966 Cutlass Convertible line replacement
Old December 21st, 2014, 05:50 PM
Larrys'66's Avatar
Before I dive into replacing the convertible tubing, does anyone have any tips or do you know of a good link on CO? I searched but didn't turn up anything.
While replacing my floor pans a few weeks ago, I noticed some oily substance under the rear seat. I assume the top is hydraulic powered.
Thanks and Merry Christmas!
Larrys'66 is offline
Old December 21st, 2014, 06:20 PM
lemoldsnut's Avatar
It is hydraulic. The lines are plastic with brass threaded ends that go on the cylinders and to the pump. Self bleeding. I put a pan I cut out of a gallon jug under my new pump when I first filled it and ran the top up and down a few times to get the air out. Worked great!
lemoldsnut is offline
Old December 21st, 2014, 07:59 PM
Junkman's Avatar
That oily substance is brake fluid, if it is original from the 1960's. It is easy to clean up with soapy water and a towel. The one problem is that it will remove any paint that it comes in contact with, so you have to be very careful. I just answered a similar question in another thread. You can read that reply here...https://classicoldsmobile.com/forums...placement.html
Junkman is offline
Old December 22nd, 2014, 07:18 AM
66luvr's Avatar
http://www.hydroe.com/Tips_-_Cylinders__amp__Pumps.html
No brake fluid please.
66luvr is online now
Old December 22nd, 2014, 03:22 PM
m371961's Avatar
X2 on hydroelectric. I used their hoses and cylinders and followed their instructions.
m371961 is offline
Old December 22nd, 2014, 06:33 PM
Gary M's Avatar
Details
Make sure you note on the pump which outlet corresponds with top or bottom of lift cylinders. If you put in new hoses incorrectly you will have to push down to raise top and vise versa. Been there. It's easy to confuse.
Gary M is offline
70 ctls
March 17th, 2015 09:18 AM
Del70
November 15th, 2013 02:24 PM
davepnola
December 2nd, 2010 09:00 PM
Flye
July 31st, 2009 04:03 PM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: 1966 Cutlass Convertible line replacement
