Reading a VIN
Old Feb 4, 2012 | 05:28 AM
BHoene's Avatar
Reading a VIN
Can anybody give me a brief tutorial in reading a 74 VIN? I have the numbers and need some help. I have looked on-line but am a bit confussed. Thanks
3G37V4M310175
Old Feb 4, 2012 | 05:37 AM
Blackpage's Avatar
Go here: http://v8cars.hu/oldsvin/decode.php
Old Feb 4, 2012 | 06:06 AM
TSMITH75's Avatar
how far back will that site decode
Old Feb 4, 2012 | 06:07 AM
1970cs's Avatar
Lansing built
adding to
V=455 4bbl according to GM dealerworld see foot note for division/make
http://service.gm.com/dealerworld/vi.../vincard74.pdf
Pat
Old Feb 4, 2012 | 06:22 AM
vette442's Avatar
It says 1946 right at the top.
Is your car a Hurst/Olds? That's a common application for the somewhat hotter V code 455/TH400 combination of 1974.
Terry
Old Feb 4, 2012 | 06:29 AM
jaunty75's Avatar
Here's another site with VIN decoding info for all GM going back to 1972.
http://service.gm.com/dealerworld/vincards/
Old Feb 4, 2012 | 07:43 AM
BHoene's Avatar
Thumbs up Vin
Thanks for all the help this morning. Yep, it is a 74 Hurst 455.
Old Feb 4, 2012 | 10:50 AM
BHoene's Avatar
follow-up question / Parts Supplier
Can you recommend a good place to get parts, emblems, etc for a 74 Hurst?
Old Feb 4, 2012 | 10:54 AM
jaunty75's Avatar
The post-1972 Cutlasses aren't as well supported by any means as the earlier Cutlasses. Several vendors cater to the Olds hobby, including Fusick, Year One, and Kanter, with Fusick devoted exclusively to Oldsmobile. Most, though, will have engine, brake, drivetrain, etc.-type parts. Body and trim will likely have to come from donor cars.
One place you'll likely run into people facing the exact issues you are is over at the '73-'77 Oldsmobile forum. If anyone does, people there ought to know about the best sources of parts for a car like yours.
http://www.73-77olds.com/
Old Jul 23, 2012 | 07:01 PM
rhurstolds74's Avatar
Emblems and stripe kits are readily available through multiple Olds catalogs. NOS seat material is at SMS in Oregon (?). Interior plastic is mostly used only with the exception of lower door panels. Body parts are used only, with the exception of floor pans, and mediocre quality quarter panels.
justagirlfromla
Mar 27, 2010 11:49 AM
71cutlasssx
Dec 20, 2009 07:19 PM
Tony Cutlass
Nov 25, 2009 05:38 PM
The Stickman
Nov 30, 2008 05:20 PM
bulldog
May 19, 2008 01:29 PM
