69 H/O guys
Old Jul 16, 2012 | 05:29 PM
'69CutlassVert''s Avatar
69 H/O guys
Does anyone have the factory measurement and placement of the trunk "blotch" stripe?
Old Jul 25, 2012 | 07:13 PM
firefrost gold's Avatar
ok if looking at the trunk from the larger part to the stripe is 19 and 3/16s from out side edge to stripe at the bottom it is 1" on the outside and 7/8ths at the key lock if You use a 4and 1/2 inch lid it will make the corner radius . That
is what mine hason the original trunk lid .
Old Jul 26, 2012 | 08:52 AM
Zackly what I needed, Thanks for your time.
Old Jul 26, 2012 | 03:01 PM
You doing a vert or hard top. ?
Old Jul 27, 2012 | 06:05 AM
Convertable. Not a true "tribute" I am replacing the Firefrost with Nassua Blue cause it came from the factory Cameo White with a bright blue interior and a blue top. My idea is 442 stripes on the hood and the single stripe under a wing on the trunk lid. Still undecided about the sides. Finish it up with Blue paint on the stage II wheels. Hanging in there with the bench seat and column shift with the numbers matching L-74 and turbo 350. Thought this would spice it up a bit and not ruin it as a clean, rust free, car.
Old Jul 27, 2012 | 11:38 AM
You will have to post some shots of it !
Old Jul 27, 2012 | 12:49 PM
Just put up a couple on the general forum.
Sixoh
Sep 19, 2018 03:56 PM
dholmes898
Jul 9, 2007 09:13 PM
Traviepoo
May 1, 2007 06:21 AM
Redog
Apr 24, 2007 03:52 PM
fnfship
Mar 11, 2005 09:12 AM
