Cowl Tag : Help Reading It
Old Mar 12, 2010 | 11:42 AM
justagirlfromla's Avatar
Can someone tell me what this means? What original color, trim, or any info? Much appreciated
Old Mar 12, 2010 | 12:01 PM
wmachine's Avatar
Trying to remember member
70-33687 70 Cutlass S Holiday Coupe
BF 00782 Fremont CA body build sequence number
943 Blue Cloth bench interior
20 20 Azure Blue top and bottom paint
09D Fourth week September build
Old Mar 12, 2010 | 12:02 PM
OMG You are flippin' AWESOME THANKS!
Old Mar 12, 2010 | 12:10 PM
If you want to find out if the engine is orginal to that car, there is a small pad on the block below the #6 head casting number and below the #1 spark plug, which is the plug on your far left standing on the drivers side of the car. This has a V.I.N. derivative stamped on it. It will tell the year of the engine block, and help match it to your car via the V.I.N. at the base of the windsheild @ the bottom of the dash on the drivers side. I f this number
Old Mar 12, 2010 | 12:11 PM
oops! if this partial number matches up with the VIN , then it is origianl to the car.
Old Mar 12, 2010 | 12:15 PM
Just to clarify,
It's above the unpainted exhaust manifold you asked about and below the head numbers your found. It's not very big and often gunked over.
Old Mar 12, 2010 | 12:23 PM
Yea i can only see the last few parts of it, part of the alternator clampy-thingy- is covering it.
Edit: The VIN ends in 3275 and the part i can see on the engine ends in CFD or CF0 or CFO
Old Mar 27, 2010 | 11:49 AM
blueRAYwhale's Avatar
Smile "I'll try to decode that tag as well"
Originally Posted by justagirlfromla
Can someone tell me what this means? What original color, trim, or any info? Much appreciated It does look as though they got it right. I will post it later, this is a great site.
preacherinseville
Jul 8, 2012 03:05 PM
preacherinseville
Jul 8, 2012 02:36 PM
preacherinseville
Jul 8, 2012 02:30 PM
71cutlasssx
Dec 20, 2009 07:19 PM
bulldog
May 19, 2008 01:29 PM
