1967 Pontiac GTO vs 1968 Hurst Olds | PURE STOCK DRAG RACE
Old August 16th, 2022, 11:35 AM
Cosmic Charlie's Avatar
Aug 9, 2022
Cosmic Charlie is offline
Old August 16th, 2022, 06:47 PM
Andy's Avatar
Damn, sorry numbers for that big 455…the mph..what happened?
Andy is offline
Old August 16th, 2022, 06:57 PM
That's a slow trap speed for the time that he ran in the H/O. I wonder if he let off or had a problem.
1969w3155 is offline
Old August 16th, 2022, 07:05 PM
some of the youtube comments say the Olds shutdown early +-
Old August 17th, 2022, 11:35 AM
Andy's Avatar
didn’t look like it to me but something happened. The olds pulled him out of the hole but that poncho ran him down.. Pontiacs about 500 pounds lighter too
Andy is offline
Old August 22nd, 2022, 01:48 PM
69CSHC's Avatar
Good stuff as usual Charlie, and great to see a "pure stock race" that ran like actual stock. I have watched the clip several times already. Thank you for posting this.
Agreed, yes on both points. 13.95 @ 93.83 does not mesh... at all. He had a car length lead off the line but somehow with enough additional horse power and gearing to overcome it's weight disadvantage, lost ...
Would love to see an all out 2 out of 3.
I think the H/O pulls it out.
In the end the H/O had a 210 lb penalty. And was still close even though he lifted... Balancing out the weight alone puts it under a 1/10th of a second difference. Great race on video, in history, and on paper.
Continued
69CSHC is offline
Old August 22nd, 2022, 01:54 PM
69CSHC's Avatar
13.95 indicates 330 HP flywheel net but the 68 H/O is underrated. It's flywheel net HP is around 350. And it's a 400/+ gross HP car when factory correct.
Below is what the MPH on a car like that, that's running that ET should of been. While entering specific test weight.
9 MPH short... The man eased of the gas with a few hundred feet to go ...
Meanwhile the GTO ran an essentially perfect pass. For a 3720 lb 330 flywheel net HP version. (And yes the GTOs gross rating was underrated as well...)
Again had the Olds ran all out. This would of went from a great to an amazing race.
P.S. as you can see Charlie I enjoyed every bit of your post. Pure pleasure dissecting it from every angle...
69CSHC is offline
Old August 22nd, 2022, 02:04 PM
69CSHC's Avatar
For those wondering about the exact results. Without watching the video. Below is a screenshot of the finish line numbers.
69CSHC is offline
Old August 22nd, 2022, 10:12 PM
I watch that YouTube channel, some of his earlier videos were pretty funny with the childish crude humor.
If that’s the same Hurst/Olds featured in some of his other videos, it definitely had a problem on that run.
There is a few videos of another barn find 68 Hurst/Olds running deep into the 12s. And before anyone starts complaining “that ain’t stock, they weren’t that fast back then!!” you need to read and understand the rules. Stock means correct heads, carb, tires, exhaust, etc. Rear gear, converter, invisible suspension modifications, etc, are all legal. Basically, it has to LOOK stock, with stock type parts, but as long as it isn’t obviously aftermarket, it’s legal.
matt69olds is offline
Supernice88
June 20th, 2022 07:49 PM
Cosmic Charlie
Hurst/Olds
February 28th, 2022 04:24 PM
Cosmic Charlie
February 14th, 2022 07:28 PM
crash
November 14th, 2018 08:23 AM
dan1s
January 27th, 2008 06:10 PM
Quick Reply: 1967 Pontiac GTO vs 1968 Hurst Olds | PURE STOCK DRAG RACE
