Rear axle codes for a 69 HO
Old Aug 11, 2021 | 01:53 PM
Ontario69Hurst's Avatar
Can someone advise where on the rear axle the code can be located. A picture would be great. My axle is somewhat dirty and I don't have access to a lift.
'SH'=3.23, 'SJ'=3.42, 'SL'=3.91
Thank you
Mark
Old Aug 11, 2021 | 02:25 PM
For the O-Type, on the passengers side axle tube, facing the rear, between the vent and the spring perch.
Old Aug 11, 2021 | 02:32 PM
It's stamped on the tube, front side, usually passenger, sometimes upside down, about in the middle from side to side. Take a flashlight and put the light sideways on the tube. Edit: Kenneth beat me.
Old Aug 11, 2021 | 02:36 PM
Koda, yours is on the front of the tube? My '71 10 bolt has the code on the front, but the three O-Types in my stash have it on the rear.
Old Aug 11, 2021 | 06:47 PM
The 67 is front right tube, the 72 is front left tube.
Old Aug 11, 2021 | 06:53 PM
Interesting. My O-Types with the code on the passengers rear are 68 and 70 vintage, and my 71 corp 10 bolt has the code on the passengers front.
Old Aug 11, 2021 | 07:13 PM
the 67 may be the back of the tube, I haven't looked in 15 years since I saw SD, confirmed limited slip, serviced it, and counted teeth.
Old Aug 12, 2021 | 06:00 AM
69 Hurst's Avatar
Olds Fanatic
I've been trying to find mine as well, no luck. Maybe too much coating.
Old Aug 12, 2021 | 06:11 AM
69HO43's Avatar
Mine is upside down on front passenger side of the tube. When I first saw it I thought it was a 7S, but it was actually SL.
Old Aug 12, 2021 | 10:37 AM
I had to wire brush the rust and oily crud off a few of mine in order to see the stamping.
Old Aug 12, 2021 | 04:02 PM
herkguy's Avatar
the 69s I had and my 70 were all in the area like first pics Fun71 posted. Back of passenger side under brake line near vent tube. Upside down was common…
a metal paint scraper and good wire brush will usually do the job.
Owen Miller
Oct 13, 2021 04:35 PM
sherlock1212
May 26, 2020 07:19 PM
caddy
Mar 15, 2013 11:00 AM
64starfire
Drivetrain/Differentials
May 18, 2011 10:57 AM
JOHNNY
Aug 6, 2006 07:21 PM
