Ported vacuum switch?
Old September 6th, 2011, 05:04 PM
hurstoldsgal's Avatar
Does anyone know where to get a vacuum hose diagram for my car?
Does this switch belong on there?
Thanks for all your help!
hurstoldsgal is offline
Old September 6th, 2011, 05:16 PM
BlackGold's Avatar
That was called a Thermo Vacuum Switch (TVS) in 1969. I don't know the application specifics for 1969, but Olds generally installed them on cars which were in greater danger of overheating -- such as cars with A/C. teh TVS serves as a last-ditch effort to cool an idling engine when the coolant temp gets real high. You generally don't need it; it's more a question of originality.
I assume you realize that two of the ports are broken off your TVS?
BlackGold is offline
Old September 6th, 2011, 05:26 PM
Thanks for the info. While cleaning this thing up we stumbled upon it and it wasnt hooked up and wasnt sure the exact routing of it. Do you know where to find a diagram? (And yes we know its broken but havent been able to find one yet. )
Tanya
Old September 6th, 2011, 05:45 PM
stevengerard's Avatar
you can buy repo's anywhere, finding an good used one or an NOS one will be pricey.
stevengerard is offline
Old September 7th, 2011, 08:06 AM
In the future, it would be helpful if you told us what your car IS... the mind reading thing STILL isn't working.
ASSuming we're talking about the 69 in your avatar photo, then get a 1969 Chassis Service Manual, which will have the diagrams.
The thermal vacuum switch is used on cars that run the vacuum advance off of ported vacuum. Since ported vacuum is zero at idle, this can cause the car to overheat when idling in traffic. The TVS senses coolant temperature and switches the vacuum advance to full manifold vacuum if the car starts to overheat. This increases vacuum advance at idle and lets the car run cooler. The use of ported vacuum for the vacuum advance is an early emissions control that was intended to reduce NOx emissions. I'm guessing that the reason why your car doesn't have the TVS installed is that the distributor is now being run off of manifold vacuum at all times. This is not a problem. Reinstall the TVS only if you care about being 100% factory correct.
joe_padavano is online now
Old September 7th, 2011, 02:04 PM
You ASSumed correct. It is for a 69 H/O and it is all factory. Thanks for the info.
Old September 7th, 2011, 03:47 PM
Thanks Steven! I appreciate your help.
Old September 8th, 2011, 03:10 AM
Yellowstatue's Avatar
Talking Dcm dcm dcm
DCM...Top port is D for Distributor and middle port is C for carb and bottom port is M is for manifold...
Yellowstatue is offline
Old September 8th, 2011, 05:28 AM
Forget he diagrams and pictures, YOU nailed it perfectly! Exactly what we were needing. Could not have asked for a better description. Thanks
(dcm dcm dcm dcm dcm dcm)
Old September 8th, 2011, 04:09 PM
BlackGold's Avatar
The "DCM" gives you the functional connections, but if you want to know how it was T-ed into other vacuum lines and/or connected to other devices (TCS, OAI vacuum motor, transmission vacuum modulator) you still need the proper vacuum diagram.
Old September 8th, 2011, 04:41 PM
Okay, here it is, but as Joe said, all you need to do is look in your Chassis Service Manual.
MDchanic is offline
Old September 8th, 2011, 07:10 PM
Thank you Eric and Brian. Very good info!
Old May 9th, 2020, 02:44 PM
Neil Morrison's Avatar
400ci
Its a PORTED VACUUM SWITCH.
Neil Morrison is offline
Old May 9th, 2020, 02:49 PM
My 1969 442 Ported Vacuum Switch, only has two hose outlets.
Which goes where ???
Thanks, neilm
Old May 9th, 2020, 03:32 PM
You need a 1969 CSM which shows the diagrams. I believe it was referred to as a TVS even in 1969 (not positive but the CSM would be the definitive source). I thought they all had three ports, but again - the 1969 CSM should be definitive. Maybe you don't have the OEM model?
Vintage Chief is online now
Old May 9th, 2020, 03:36 PM
It would appear eric provided pictures/images/diagrams of a 1969 TVS in Post #11. If yours only has two outlets, it's doubtful you have an OEM TVS.
Old May 9th, 2020, 03:44 PM
Thanks, neilm
The original TVS has THREE ports. Yours has been replaced with an incorrect one, apparently. A photo would help us identify it. And Oldsmobile calls it a Thermostatic Vacuum Switch, thus TVS. Pages 6K-9 and 6K-10 in the 1969 Chassis Service Manual have the hose connections.
Old May 9th, 2020, 03:49 PM
This is what the correct, factory TVS for a 1969 looks like. You will note if you look closely that the ports are labeled "C", "D", and "M", which is what I told you when you asked this same question on May 6 in THIS thread.
Mongoose
March 24th, 2014 01:54 PM
Olds luvr
April 4th, 2011 12:30 PM
esisson
June 8th, 2008 07:59 PM
dan1s
February 18th, 2008 11:41 AM
ct1979
December 22nd, 2006 10:22 PM
Quick Reply: Ported vacuum switch?
