intake's
Old Jan 8, 2010 | 04:15 AM
firefrost gold's Avatar
intake's
I have seen torker intake's on 68 ram air tube set ups but what will fit a 69 or has any one used say a torker or holley street dominator or seen one on a 69 h/o? .
Old Jan 15, 2010 | 08:09 PM
Cameo White's Avatar
Smile
Back in the day a lot of the 69's had the cast iron manifold dumped early on. I've got a copy of a document from Hurst from back in the day I got from one of the long time 69 H/O guys on here that talks about other performance mods they recommended back then. If I remember, it had an intake swap in it. PM me your email address and I will dig it out and send it to you.
Old Jan 16, 2010 | 06:11 PM
69 H/Os have the same problem as the 70-72 O.A.I. cars - if you plan to keep the stock air cleaner and O.A.I. adapter, a taller intake may cause hood clearance problems.
Old Jan 17, 2010 | 06:55 AM
MN71W30's Avatar
Hey Neighbor, I,m just down the road.
If your running a stock 400 or a 455 Olds motor, I'd consider sticking with a dual plane intake. I've been down that road twice before only to be let down because of the loss of low end torque. If you've had head work etc. thats a different story. I had a torker on a 68 W30 with the hoses and it fit fine the best I can recall. We also installed one on a 69 442 and lost a tenth or two at the track. In both cases it there was a noticable loss of low end power.
Have you had your car at the no. st. paul show? if so what color is it?
Dave
Old Jan 24, 2010 | 03:16 PM
No i have not had it at north st paul I just picked it up. When I get some time and to figure out how to put up some photo's the motor is not running so that is why im looking for combo's I will not get it running till next year unless I drop cheap runner in it for short time??? I would even put a olds 350 for temp set up if a could find a cheap one should bolt up.
Wildcard
Dec 26, 2012 07:48 AM
Nickyloves442s
Oct 24, 2012 04:55 PM
svnt442
Jul 17, 2011 04:43 PM
71cuttyS
Oct 31, 2007 04:58 PM
