correct location of ignition coil
Old May 8, 2013 | 08:04 AM
pogo69's Avatar
morgan
i'm replacing my ignition coil and was looking in the 1969 service manual sec 12 page 49...it shows the positive coil terminal on the left side of car, now my old one has the pos. terminal on the pass side...what is correct?
Old May 8, 2013 | 09:22 AM
Octania's Avatar
seriously?
Positive on TOP!
I don't think it matters, as long as the wires reach the terminal they need.
(-) closest to distributor would make sense.
Old May 8, 2013 | 02:25 PM
pogo69's Avatar
morgan
Ok here is why i want to know...if the negative is on the right as i am facing it(left side of car) then the delco remy is readable....if the positive terminal is on the left the delco remy is upside down BUT the embossed 238 b-r is readable and on top the embossed number would be on the bottom of the coil with the neg post on the left
Old May 8, 2013 | 03:46 PM
rcorrigan5's Avatar
Randy C.
I don't know if this is relevant or not - different engines and different assembly plants - but here's how the coil is mounted in my '69 Fremont 4-4-2. I don't have any reason to believe it has ever been removed and re-installed - it's pretty crusty under the hood. The (-) terminal is inboard.
Randy C.
Old May 8, 2013 | 04:31 PM
pogo69's Avatar
morgan
Randy C.
thanks for the pic that is also how my old one was mounted but the service manual has it with the pos inboard i guess the manual could be wrong
805cut
Sep 3, 2012 10:53 AM
stevengerard
Feb 14, 2010 07:30 AM
OlBluehairCruiser
Jul 31, 2009 08:33 PM
1FSTLS1
Dec 20, 2008 05:45 AM
68conv455
Feb 20, 2008 02:36 AM
