64' F-85 intake to hood clearence/correct alt.location
Old Jul 11, 2009 | 05:32 PM
OlBluehairCruiser's Avatar
[1] -Has anyone replaced a stock 4 bbl. intake with a high rise Edlebrock Performer on the 330 engine. It is suppose to be 2" taller than Oem and if so was there adequate hood clearence. [2] - anyone know the correct location for the alternator on the 64' 330... There are 2 that I know of the midmount passenger side and the lower mount on the passenger side. My car came with a home made apparatus that the previous owner installed because he tried to put ac in a car that never had it.
Old Jul 11, 2009 | 05:51 PM
Wasted's Avatar
I dont know the answer to 1, but this picture should help you out with #2.
http://img20.imageshack.us/img20/801/dscn8327y.jpg
This is of my engine(64 330) when I got the car.
Old Jul 12, 2009 | 06:42 AM
442scotty's Avatar
I have a performer manifold and edelbrock carb in my 65..on a 455..
It will fit and you will have to get the lowest sitting air cleaner out there...
Old Jul 12, 2009 | 05:43 PM
Thanks again to both Wasted and 442scotty for the info.
Old Jul 13, 2009 | 07:31 AM
Note that 1964 has one-year-only accessory brackets. This is due to the driver's side water pump inlet and the fact that there was no big block in 1964. The water pump issue resulted in accessories being located differently than on later Olds motors.
Old Jul 13, 2009 | 09:37 AM
Boldsmobile's Avatar
I can provide more pics if needed.
Old Jul 13, 2009 | 07:01 PM
Thanks guys now I just need to find the brackets and I'll be set. Posted a thread in the parts wanted section for these.
Old Jul 31, 2009 | 08:33 PM
64 Cutlass's Avatar
Just so you can see, my '64 has the alternator mounted high on the driverside. It has A/C and PS, but not PB?(maybe someday)
zgzmithr
Feb 26, 2015 07:36 PM
pogo69
Hurst/Olds
May 8, 2013 04:31 PM
ELECMAN
Dec 1, 2011 07:52 PM
svnt442
Jul 17, 2011 04:43 PM
1966_F85
May 24, 2010 03:28 PM
