69 H/O Driveshaft
Old May 8th, 2021, 05:26 PM
briane's Avatar
69 H/O Driveshaft
Would the 1969 Hurst Olds originally have a one- or two-piece driveshaft?
briane is offline
Old May 8th, 2021, 08:37 PM
FStanley's Avatar
one piece for sure.. same as 442 with a TH400 trans
Fred
FStanley is offline
Old May 8th, 2021, 10:33 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
All automatics got the "concentric" shafts with the rubber insert. (AKA but not really a two piece). Easily put out of phase with a nasty automatic + dry rot.
All stick cars got the standard single-tube everyone's familiar with.
This statement applies to 68-72 Olds A-bodies
droldsmorland is offline
Old May 9th, 2021, 01:18 AM
^^^This. My crewcab dually has a "two piece" driveshaft - there's a center bearing and a third u-joint in the middle. All 68-72 AT cars got the concentric driveshaft with the rubber insulator. It's still considered one piece, since it only has two u-joints.
joe_padavano is online now
Old May 9th, 2021, 03:40 AM
briane's Avatar
By 2-piece I was thinking of the concentric shaft design as opposed to two shafts in series. So I gather a concentric shaft is original to the 1968, 69, 72 H/O's. FStanley in your response you were referring to 2 shafts in series?
Thanks.
briane is offline
Old May 10th, 2021, 06:09 AM
83hurstguy's Avatar
The concentric shaft design was original to '68 H/O, can't speak to the others.
83hurstguy is offline
Old May 10th, 2021, 06:15 AM
Also my 69 H/O
Old May 10th, 2021, 06:23 AM
briane's Avatar
Thank you Luke. I've been contacting a number of people and it seems at some point, post 1968, there may have been a transition from the 2-piece concentric to 1-piece solid for the 442 TH400 vehicles. More homework to be done here.
Last edited by briane; May 10th, 2021 at 11:25 PM. Reason: spelling error correction
briane is offline
Old May 10th, 2021, 06:24 AM
briane's Avatar
Joe, thanks for checking your own '69 H/O. Can you share the build date on your car?
briane is offline
Old May 10th, 2021, 10:04 PM
FStanley's Avatar
Thanks.
don't know what concentric means,etc etc all I know it that it looks like this..
FStanley is offline
Old May 11th, 2021, 04:15 PM
72 Olds CS
RetroRanger's Avatar
that looks like a a 2 piece (concentric w 1 shaft inserted into the other and held by a rubber insulator) see the squarer transition near the back of the shaft the 1 piece shaft is all smooth transition like the first diameter change nearer the center of the shaft
RetroRanger is offline
jersey2phx
Cars Wanted
180
January 8th, 2017 11:45 PM
Boilerz25
April 5th, 2014 04:04 PM
miko442
July 9th, 2013 06:11 PM
Mr Nick
July 5th, 2013 03:24 PM
Harv
Cars Wanted
February 5th, 2012 04:06 AM
Quick Reply: 69 H/O Driveshaft
