69 H/O Driveshaft
Old May 8, 2021 | 05:26 PM
briane's Avatar
69 H/O Driveshaft
Would the 1969 Hurst Olds originally have a one- or two-piece driveshaft?
Old May 8, 2021 | 08:37 PM
FStanley's Avatar
one piece for sure.. same as 442 with a TH400 trans
Fred
Old May 8, 2021 | 10:33 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
All automatics got the "concentric" shafts with the rubber insert. (AKA but not really a two piece). Easily put out of phase with a nasty automatic + dry rot.
All stick cars got the standard single-tube everyone's familiar with.
This statement applies to 68-72 Olds A-bodies
Old May 9, 2021 | 01:18 AM
^^^This. My crewcab dually has a "two piece" driveshaft - there's a center bearing and a third u-joint in the middle. All 68-72 AT cars got the concentric driveshaft with the rubber insulator. It's still considered one piece, since it only has two u-joints.
Old May 9, 2021 | 03:40 AM
briane's Avatar
By 2-piece I was thinking of the concentric shaft design as opposed to two shafts in series. So I gather a concentric shaft is original to the 1968, 69, 72 H/O's. FStanley in your response you were referring to 2 shafts in series?
Thanks.
Old May 10, 2021 | 06:09 AM
83hurstguy's Avatar
The concentric shaft design was original to '68 H/O, can't speak to the others.
Old May 10, 2021 | 06:15 AM
Also my 69 H/O
Old May 10, 2021 | 06:23 AM
briane's Avatar
Thank you Luke. I've been contacting a number of people and it seems at some point, post 1968, there may have been a transition from the 2-piece concentric to 1-piece solid for the 442 TH400 vehicles. More homework to be done here.
Last edited by briane; May 10, 2021 at 11:25 PM. Reason: spelling error correction
Old May 10, 2021 | 06:24 AM
briane's Avatar
Joe, thanks for checking your own '69 H/O. Can you share the build date on your car?
Old May 10, 2021 | 10:04 PM
FStanley's Avatar
Thanks.
don't know what concentric means,etc etc all I know it that it looks like this..
Old May 11, 2021 | 04:15 PM
RetroRanger's Avatar
72 Olds CS
that looks like a a 2 piece (concentric w 1 shaft inserted into the other and held by a rubber insulator) see the squarer transition near the back of the shaft the 1 piece shaft is all smooth transition like the first diameter change nearer the center of the shaft
jersey2phx
Cars Wanted
180
Jan 8, 2017 11:45 PM
Boilerz25
Apr 5, 2014 04:04 PM
miko442
Jul 9, 2013 06:11 PM
Mr Nick
Jul 5, 2013 03:24 PM
Harv
Cars Wanted
Feb 5, 2012 04:06 AM
