1969 H/O air cleaner element
Old Apr 26, 2010 | 12:22 PM
slowolds's Avatar
Loose Radical
Could someone post a brand/part number for a'69 H/O air cleaner element?
I was looking at one and it is not very tall. I would think you would want as much filter area as possible.
Old Apr 26, 2010 | 02:29 PM
1969Hurst's Avatar
s/b AC366C or WIX 42102, going to be about 2.5 inches tall, an element of 3 inches will not fit under the '69 flapper top unit as the lid will run into the vaccuum unit.
Old Apr 27, 2010 | 11:10 AM
slowolds's Avatar
Loose Radical
Old Apr 27, 2010 | 11:39 AM
Don't forget the holes in the bottom of the air cleaner
http://members.***.net/witrob/scoop/scoop.html
Old Apr 27, 2010 | 01:58 PM
slowolds's Avatar
Loose Radical
AC366C Discontinued
So that looks like a service bulletin.
So your car would only have holes it you took it in for service, correct?
Old Apr 27, 2010 | 04:41 PM
1969Hurst's Avatar
Fusick lists an AC366C that they are selling, not sure if they list it and then send an equivalent, may want to contact them.
As far as I know the holes would only be there if you took it in for the service as it was to correct the stock unit.
Do you have a '69 that you are currently restoring?
AC366C Discontinued
wmlewis
Nov 1, 2014 11:22 AM
66luvr
Jul 29, 2013 11:54 AM
tgilligan
May 21, 2013 10:24 AM
stratoblues
Aug 2, 2012 03:26 PM
Nilsson
Apr 19, 2010 04:49 AM
