1968
Old Feb 14, 2012 | 01:21 PM
Benton Quest's Avatar
No Dr. but play 1 on TV
1968
Can someone pm me with a phone number so I can get some help identifying this car I found? Thanks.
Old Feb 14, 2012 | 01:31 PM
allyolds68's Avatar
Let's try this a different way. Please PM your number with the info that you're looking for & I'll see if I can help. If It's a 68 H/O I may or may not be able to help
Old Feb 14, 2012 | 03:48 PM
jaunty75's Avatar
Benton Quest
That is hands down the best username I've seen!
Old Feb 15, 2012 | 03:11 AM
Yellowstatue's Avatar
Not as good as Benton Harbor !!
Old Feb 21, 2012 | 05:59 AM
Hi All,
I haven't had any help yet. Anyone else willing to listen to what I have or look at some pics for me? I would say it is a solid three car and it looks very orig except one fender repaint.
Send me a pm if you have knowledge of these cars. It will be gone to someone by Thursday.
Thanks.
Old Feb 21, 2012 | 08:24 AM
fourtwenty's Avatar
Post the vin and someone will tell you exactly what you're looking at. Also post some pics. orrick@telus.net
Old Feb 21, 2012 | 08:39 AM
allyolds68's Avatar
It's a difficult to find out info for 68 H\O's. The VIN info is out there (not publically) but it's apparently closely guarded. I wonder what it takes for them to confirm you have a real one?
Old Feb 21, 2012 | 08:56 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Try Karl Sarpolis, he's the '68 H/O advisor.
karlskorner@msn.com
Old Feb 21, 2012 | 11:30 AM
Here r the details. The vin is a real H/O.
The cowl tag has the correct H/O info. Owner has an invoice on the car. I need someone to look at my pics and tell me if it is a matching numbers car like the owners says it is. Or tell me what to look for on the engine to make sure.
Old Feb 21, 2012 | 11:37 AM
allyolds68's Avatar
There's a machined pad on the block just below the number one cylinder. It's probably obscured by the power steering pump bracket (or another backet because I think you said this was an A/C car) and covered with grime. It should have 38MXXXXX with the XXXXXX being the last 5 or 6 numbers in the VIN.
The tranny should have an "OW" tag with the vin number stamped somewhere on it (I don't know where, someone else will need to chime in).
Also read the section here on 68 H/O's:
http://www.442.com/oldsfaq/ofhos.htm
Here's a pic I stole from someone else here:
Old Feb 21, 2012 | 02:39 PM
driverchoice's Avatar
vin should be on left side of tranny in front of reverse switch / above shift cable bracket
Old Feb 21, 2012 | 02:42 PM
oldsguybry's Avatar
NOVICE car nut
38Mxxxxxx , I have a 76 Olds motor in my 72 CS and has a 36Mxxxxxx .... what is the 3 for ? I tried to look on that decoder , but seems that portion is not there for a 76
Old Feb 21, 2012 | 03:20 PM
allyolds68's Avatar
It's been a while & I was going off memory. I don't think there was anything that differentiates a 1968 from a 1978 but I could be wrong (I don't believe the 455 was produced in 1978 anyway)
3- Oldsmobile
8- 1968
M- Lansing
Old Feb 21, 2012 | 03:50 PM
oldsguybry's Avatar
NOVICE car nut
ahhh , thanks for the info
Old Feb 24, 2012 | 04:23 AM
firefrost gold's Avatar
google 68 hurst olds. You will find lots of info like tag paint code should be - -
not a code. red federwells, ram air cars got C heads , non air cars D on air cars. Walnut shifter plate not the burlwood like the more comon 69 style shifter plate. 14" wheels . What are you looking to find out ?
Old Feb 24, 2012 | 04:37 AM
vette442's Avatar
Why not post the pictures here then? Load them to photobucket and cut/paste the IMG link into this thread. Then you'll have a few dozen people eagerly checking them out for you. Takes five minutes, tops.
Old Feb 24, 2012 | 05:26 AM
not a code..............NO, PAINT CODE SHOULD BE Z-Z !
Old Feb 24, 2012 | 11:31 AM
I stand corrected do or dont they come with both Z and or - ??
Old Feb 24, 2012 | 02:35 PM
pics. What do you think?
Old Feb 24, 2012 | 02:38 PM
more
Old Feb 24, 2012 | 02:41 PM
last ones.
Opinions please.
Old Feb 24, 2012 | 03:36 PM
allyolds68's Avatar
Just Z-Z
Benton,
Buy it
Old Feb 24, 2012 | 03:56 PM
Wrong wheels and some added pinstripes( and h/o around steering column) but looks pretty good to me
Old Feb 24, 2012 | 03:58 PM
What other options besides a/c and pwr ant?
Old Feb 24, 2012 | 04:28 PM
allyolds68's Avatar
I thought they came with 14" bolt on SSII's and the Hurst wheels were an option, no? The 5 stainless trim inserts were probably added. The color looks a little dark but I think they're probably the right rims
Old Feb 24, 2012 | 04:42 PM
No they are 70 and up rims see how deep the trim rigs are they should not have to go so far to meet the face of the rim and rings should be brushed
Old Feb 24, 2012 | 04:50 PM
Old Feb 24, 2012 | 05:04 PM
allyolds68's Avatar
15x7's?
Old Feb 24, 2012 | 08:11 PM
car evaluation
I'm just trying to figure out if it is matching numbers type of car.
Original engine, transmission etc.
B
Old Feb 24, 2012 | 08:14 PM
Then you need to follow the advice above and check the numbers.
Old Feb 24, 2012 | 08:24 PM
  #31
2blu442's Avatar
The posts above showed where the engine vin would be. This post shows where the transmission vin is stamped, on the drivers side. The tag with OW would be on the passengers side. As Firefrost said, since its an AC car it will have the more common C heads rather than the D heads. John
https://classicoldsmobile.com/forums...-original.html
Old Feb 24, 2012 | 08:28 PM
  #32
2blu442's Avatar
Unless you think the price is too high, I wouldn't dilly dally. Someone else may buy it before you make up your mind. John
Old Feb 24, 2012 | 08:31 PM
  #33
+1.
I'm NO H/O expert (okay, I know nothing about them), but judging by my experience with old cars in general, and by what I can see from those pictures, that car looks very original to me.
I'd be strongly inclined to buy it and keep it in that exact condition.
Old Mar 3, 2012 | 02:12 PM
  #34
looks like a nice car did you get it or any info what price do they want if you are not in are you willing to share info?
Old Mar 5, 2012 | 06:41 AM
  #35
Hi Guys,
Looked at the car again.
Picking it up this week or next.
Will send better pics when can.
Thanks for help.
BQ
Old Mar 23, 2012 | 01:22 PM
  #36
Hi All,
This story has taken a turn for the worse.
I'm not going to give the whole story, it would take too long.
After seller telling me he would get organized and sell me the car, he let one more person look at it. He told the person he was selling to me, but he wanted to look at it anyway. The person looked at it for a while. Asked if he could take pics of title and docs. He did and left. When seller went to get items together for me he could not and still can't find the title.
I'm still hoping it will turn up, but it has not yet.
Very sad song here.
Old Mar 23, 2012 | 01:30 PM
  #37
jaunty75's Avatar
So he thinks the guy who took the pics took the title? That really doesn't make sense as what value would it be to him without the car to go with it?
It's more likely the seller just misplaced it, or the guy who took the photos took it by accident. Regardless, it shouldn't be that difficult for him to get a replacement title. People do lose them sometimes, and states have ways of replacing them. It might take you a little longer to get the car, but if everything is above-board here, you should still end up with it.
What you need to do is enlist the aid of Race Bannon, Hadji, your son, and Bandit!
Old Mar 23, 2012 | 01:42 PM
  #38
Yes, Bandit would be the biggest help.
The owner does say he took it. He really doesn't know where it is.
I'm holding out hope.
Old Mar 23, 2012 | 02:19 PM
  #39
Sounds like he changed his mind and is giving you a BS excuse to flick you off.
If he really lost it, it should be no problem to replace it.
Probably buyer #2 offered him more $$$$$..
That's why when it looks like a really great deal, you show up with a trailer and cash. When these things drag on they get ugly.
Old Mar 23, 2012 | 04:58 PM
  #40
x2
