83 H/O door window seal
I am needing the rubber strip that goes at the bottom of the window and the top of the door that keep debris and water from getting down inside the door. Has anyone replaced this seal and where is a good place to buy these from?
The information below is from Rock Auto..... they are not as good as the factory OEM's, but they will work if you have no other options.... I would search the internet for the GM part numbers which are listed in brackets after the Fairchild part number....
1983 OLDSMOBILE CUTLASS SUPREME 5.0L 307 cubic inch V8 : Body : Belt Weatherstrip / Window
Scraper Seal
PriceAdd to CartIndividual Piece FAIRCHILD Part # G2109 More Info {#20363107}
Inner; Driver Side; 2 Door* Stocked in outlying warehouse--shipping delayed up to 2 business days
$27.89 FAIRCHILD Part # G2110 More Info {#20363106}
Inner; Passenger Side; 2 Door* Stocked in outlying warehouse--shipping delayed up to 2 business days
$27.89 FAIRCHILD Part # G2113 More Info {#20674279} Will not fit w/ reveal molding
Outer; Driver Side* Stocked in outlying warehouse--shipping delayed up to 2 business days
$31.89 FAIRCHILD Part # G2114 More Info {#20674278} Will not fit w/ reveal molding
Outer; Passenger Side* Stocked in outlying warehouse--shipping delayed up to 2 business days
$31.89Kit
Scraper Seal PriceAdd to CartIndividual Piece FAIRCHILD Part # G2109 More Info {#20363107}
$31.89Kit
I got this info from Olds Power. Try these for research, prices may have changed though.
For G47 WITHOUT T-tops:
20737658 RH Window/Roof Side Seal $121.94
20737659 LH Window/Roof Side Seal $121.94
20201220 RH Door Weatherstrip $102.63
20201221 LH Door Weatherstrip $71.26
20490800 Trunk seal (Trim to fit, glue the ends) $53.00
Window sealing strips
The stainless is
long since discontinued. You have to dismount the old rubber on it and mount
the new rubber on the stainless. They are different than the ones with the
bead. However, the rubber section only is available
20674276 for RH $28.11
20674277 for LH $23.50
The one with the narrow bead is still available too. It's for Calais, and
non-B85 cars. G47 applications,
20674278 for RH $43.35
20674279 for LH $43.35
The inner strips are the same for all of the 2 door G, 81-88
20363106 for RH $45.73
20363107 for LH $50.63
The stainless is
[QUOTE
=truckerlary;787893]It says it will not fit with reveal moulding. What is this moulding?[/QUOTE]
The molding referred too is the BX85 trim for the G-Body Cutlass.... Your Hurst does not have that trim.....
=truckerlary;787893]It says it will not fit with reveal moulding. What is this moulding?[/QUOTE]The molding referred too is the BX85 trim for the G-Body Cutlass.... Your Hurst does not have that trim.....
1965cutlassragtop
May 8, 2012 01:00 PM
f-85
Jan 16, 2012 06:10 AM
