Atomic EFI
Atomic EFI
Hi all,I am going to put fuel injection in I had it with carbs,I seen a post here about inline inc fuel tanks,can't find it now anyway I am using Msd Atomic efi with a return I was going to use the pump you put near the fuel tank but it says you should use a in tank pump,inline has one for a 67 olds the problem is the fuel pump feed is 1/4 and I'm told 3/8 is better any help or advice would appreciated,I think I got everything figured out but the 1/4 feeds has anyone ever installed atomic efi ,or the inline tank w/there pump
Steve
Steve
Didn't one of the big mags just do a test on all the setups? I am thinking of putting this on my Vette. I just looked around for it and couldn't find it. Here's a link. http://www.carcraft.com/techarticles...ultipoint_efi/
Call MSD, they'll help you.
Good thread thanks again
Steve
I emailed tank inc about my ? They sent back this
The 1/4 is a NPT fitting which is the same as 3/8” I hope this helps.
I don,t get it
Steve
I don,t get it
The different thread styles are measured differently.
A 1/4 NPT is the same as 3/8 and -6 fuel lines.
http://www.summitracing.com/parts/sum-220647b
I have the FAST EZ EFI with in tank pump on my Cutlass, I'd be glad to help with any questions you have.
