making tribute 68 442 - what emblems are right?
Need your help once again and cant think of a better place to ask.
I have a 68 S and creating a tribute 442. I see a lot of pics on line of 68 442's with the no emblems on the hood - no rocket or oldsmobile script on right side the I see some that have just oldsmobile and so on - same goes fore the rear. Anyone know what's right or is a there a place that has that info?
appreciate you responses.
Rich
Rich
so no rocket emblem on hood or oldsmobile script on drivers side of hood. and a rocket on back with of course 442 on right. If you do a google search you see so many different variations
thanks for you help. Any pics of the 68 you have?
rich
google search you
see so many
Np, check out my user name and see my pics of 68 convert
Dean
rich
google search you
see so many
Dean
rich
note please that '68 numerals [don't get to use that word much] are shorter and fatter than '69-72 versions, and black surrounded by a single chrome outline.
http://www.ebay.com/itm/68-OLDSMOBIL...be3ce9&vxp=mtr
So, to sum up:
442 in the center of your new rectangle style black "frill" :-)
http://www.ebay.com/itm/1968-Oldsmob...a9a600&vxp=mtr
442 on RH side of decklid
442 on each front fender, located differently depending on whether you use the W36 vertical stripe or not- see other thread for the nitty gritty.
442 on glovebox door- see Fusick's perhaps?
Remove Other scripts and whatnot from hood
Rocket emblem on decklid center
Hood should have raised center section like Cutlass S
Wheel opening trims are also like Cutlass S, nut Cutlass
what'd we miss?
My glovebox has a cutlass metal stick on badge within a raised box and an S to the right of that- Is the 442 glovebox door different or does the 442 go inside that raised box/outline. Anyone have a good spot to pick one of those up if different
Good so far
So, to sum up:
what'd we miss?
So, to sum up:
what'd we miss?
OPGI also sells re-pop 442 glove box door emblems. It fits in the same place your "Cutlass" emblem fits. However, you may have to remove the "S" to the left of it to make it look like a 442 glove box door. Not sure if that'll leave a mark or not. I've also seen complete 442 glove box doors on Ebay, I believe one from a '69 also fits.
Here are pics of my 68 442 you may be able to use as reference.
http://www.ebay.com/itm/Oldsmobile-4...US_Cars_Trucks
Thank you - helps out alot.
davesdelta
Jul 2, 2012 07:38 PM
