Do SBO/BBO share any pieces with Buick 455?
Old Jan 23, 2014 | 08:27 AM
halfmoontrail's Avatar
I'm piecing together a Buick 455 for my '71 GS, and I still lack some odds and ends. I have several Olds 350s and 455s and associated parts.
Specifically, I'm wondering about:
- Lifters
- Pushrods
- Head bolts (I know, I know, never reuse...)
- Valve train rocker parts
Thanks in advance, Steve
Old Jan 23, 2014 | 08:54 AM
66400's Avatar
No to every thing except I do not know about the lifters.
Henry
Old Jan 23, 2014 | 08:55 AM
redoldsman's Avatar
Proud Viet Nam Veteran
The only thing for sure is the distributor cap. Lifters, maybe. Somebody else will be able to confirm that.
Old Jan 23, 2014 | 09:15 AM
Octania's Avatar
Distributor cap
points
coolant
pretty short list.
Entirely different GM groups designed these motor families.
Now as for never re-using the head bolts...
The factory manual does not say that. These are not "torque to yield" bolts. They should last just about forever.
Old Jan 23, 2014 | 09:32 AM
costpenn's Avatar
Thermostat - lol..
Old Jan 23, 2014 | 10:20 AM
Originally Posted by Octania
Distributor cap
points
coolant
pretty short list.
Aw, c'mon Chris. The list is MUCH longer:
Rotor
Bellhousing (usually, some only have a RH starter notch)
Carb gasket
Ignition coil
At least with a Pontiac motor, the starter also interchanges.
Old Jan 23, 2014 | 10:45 AM
oldsmobiledave's Avatar
more
Pontiac & olds same lifter. Buick different.
I hear they use the same oil & spark plugs though.
Block, rods, pistons, heads, intake, water pump all different.
Old Jan 23, 2014 | 01:10 PM
costpenn's Avatar
Valve stem seals would be the same, and you could cheat a little and use .020 oversize 455 Olds rings in a std bore Buick 455.
Old Jan 24, 2014 | 12:46 AM
nsnarsk65cutlass's Avatar
Distributor cap
points
coolant
pretty short list.
Until they break when torquing.
Old Jan 24, 2014 | 03:02 AM
What are you talking about?
There is no need to use new head bolts when assembling stock-spec. Olds engines.
arodenhiser
Apr 20, 2016 08:38 PM
Al2011
Aug 8, 2011 01:41 PM
Gbobby
Jun 16, 2009 01:10 PM
shaks 442 clone
Sep 17, 2007 06:06 AM
GoldOlds
Jun 11, 2007 04:21 PM
