Jack mech. And jack base colors
Old March 5th, 2013, 04:35 PM
NDERISE's Avatar
Question Jack mech. And jack base colors
Can any one tell me what color to paint my jack mechanisum and the base and the lug wrench is it satin black or gray
thanks for any help
O MY CAR IS A 70 442 HT
NDERISE is offline
Old March 5th, 2013, 08:17 PM
O's_Car's Avatar
Here's a picture of the bumper hook and base from my 70 Cutlass S before I had them powdercoated. Only the hook was gray, the base, mechanism, and wrench were all black.
O's_Car is offline
Old March 5th, 2013, 09:33 PM
orange442's Avatar
I have several 70 jacks and bases and they are all grey and none of the bases look like the one Oskar has pics of above. My 55k original mile W-31 had its complete jack assembly and it is all grey including the handle. Others I have are from 70 442 and 70 F-85 and are also grey. Also, all of my Olds jack shafts are the larger/wider more tapered rectangle versions and not square like Oskars base.
Oskar, does your base have a U70 stamped into it? All mine have that and I have several 69 jacks with U69 stamped. I am not saying your base is incorrect it just looks closer to my 71-72 jack bases for my Chevy cars that are black and are not dated/stamped.
orange442 is offline
Old March 6th, 2013, 10:33 AM
Randy C.
rcorrigan5's Avatar
I know for '68 and '69 there were 4 different manufacturers for jacks and I suspect the same was true for 1970. And each manufacturer had their own jack column shape. The picture below shows 3 of the 4 different shapes. The grey one is out of my '68 4-4-2 (Lansing car). The black one is out of my '69 4-4-2 (Fremont car). The blue one is out of my '70 GTO (also a Fremont car). I have a friend with a '71 4-4-2 (Fremont car) whose jack base/column shape is the same as my '70 GTO. At one time I thought the jack column shape was related to which assembly plant the car came from, but now I believe it was just a toss up, depending upon availability.
Randy C.
rcorrigan5 is offline
Old March 6th, 2013, 10:36 AM
NDERISE's Avatar
Thanks to all
THANKS TO U GUY FOR YOUR REPLYS, I THINK I WILL GO WITH THE GRAY ANY ONE KNOW OF THE COLOR TO USE MAY-BE A RATTLE CAN SPRAY COLOR
THANKS RAY
NDERISE is offline
Old March 6th, 2013, 10:47 AM
69'442's Avatar
I found this. I used the Federal Grey
On the 1970 Cutlass/ 442/ F85 406925 is the correct number for jack craddles. The base will have "U70" stamped on it. The "lift" will have the date code stamped on the rivet. (ie 0B for February 1970) Plasti-coat T-37 Federal Grey is an accurate colour for the lift, craddle and base. The shaft is plated in gold cad.
69'442 is offline
Old March 6th, 2013, 10:53 AM
stevengerard's Avatar
mine is grey as well for 1970. I used a rattle spray grey that matched perfectly - I'll see if I can find it. Might have been the Krylon or Rustoleum
stevengerard is online now
Old March 6th, 2013, 12:28 PM
junior supercar's Avatar
Randy C.
I have seen the same thing. diff plants. diff jack suppliers. it just depends.
junior supercar is offline
Old March 6th, 2013, 01:49 PM
Lance
ROCKET VAPOR's Avatar
My Fremont built '70 original jack base is black, the hook is dove gray, the lug wrench with the large "O" on the head is black, the mast mechanism is black, and the mast is plated in silver cadmium. I don't have a photo of the hook, but it still wears both the original white decal with red lettering and black rubber pad. Here is a before and after of the jack base.
ROCKET VAPOR is offline
Old March 9th, 2013, 06:55 PM
NDERISE's Avatar
Thanks for takeing the time to post your pics and repyls and info.
Ray
NDERISE is offline
Old March 10th, 2013, 09:23 PM
O's_Car's Avatar
My base doesn't have any stampings. Mine is a Fremont built Cutlass, and the jack assembly is just as ROCKET VAPOR described. Now, my dad did buy the car used from a Chevy dealer in California, so maybe it's not factory original.
O's_Car is offline
rhett838
September 24th, 2013 01:55 PM
Macadoo
August 29th, 2013 05:38 PM
Mr Nick
February 17th, 2013 02:35 PM
juteprechtel
May 31st, 2010 03:50 AM
65cutty
October 30th, 2008 10:26 AM
Quick Reply: Jack mech. And jack base colors
