1968 cutlass exhaust manifolds
Old May 25, 2011 | 09:34 AM
1968Cutlassfallbrook's Avatar
Hello,
I was wondering if the big block exhaust manifolds would bolt up to the small block 350 and what would be the benefit of doing so would it breath better as I'm thinking the big block has larger ports on the inside also they're setup for dual exhaust without having to bolt a plate on.
Old May 25, 2011 | 02:15 PM
Originally Posted by 1968Cutlassfallbrook
Hello,
All Olds heads have the same exhaust flange shape and bolt spacing, so yes, the BBO manifolds will bolt to the heads. Unfortunately, if you are trying to use the individual runner W/Z manifolds from the 69-72 A-body cars, these will NOT clear the rest of the motor, the motor mounts, or the oil filter adapter. Many have tried, none have succeeded. Not even Olds was able to do it, which is why even W-31 motors came from the factory with the same SBO manifolds as every other Cutlass. Other BBO manifolds besides the W/Z are smaller and may clear, but there is little value in that swap since they don't really flow any better.
And now someone will bring up the Thornton manifolds...
Old May 25, 2011 | 06:49 PM
..................And now someone will bring up the Thornton manifolds...
Why? It's been beat to death more than a few times. No need to rehash. Anyone who wants info on the Thorntons manifolds can use the 'Search' tool on the site. Saves time and avoids having to repost the same old same old....
Great info on the WZ manifolds though. Thx!
Old May 26, 2011 | 09:03 AM
Yeah, just like the motor mount question...
dnmfranco
Sep 27, 2013 09:32 PM
ardo00
Mar 28, 2013 12:14 PM
fast67vellen2o
May 20, 2012 01:21 PM
72 Olds Project
May 19, 2011 12:38 PM
67cutlass442
Sep 20, 2009 06:53 PM
