71 Delta 88 Steering Column.
Old Feb 15, 2011 | 04:23 PM
77GCSX's Avatar
How hard is it to swap one of these out? If there is a "How To" somewhere that would be even better!!
Thanks, Paul
Old Feb 15, 2011 | 05:13 PM
Bluevista's Avatar
Registered
No big deal, it's actually a pretty easy job.
If you want to change the steering wheel or ignition switch you'll need a steering wheel puller and lock plate remover tool.
The only "How To" is the 1971 Oldsmobile chassis service manual.
If you promise to get the car's instructions in the future... I'll tell you that if you register at Wild About Cars Online then go to the downloads section you can look at the '71 service manual.
The column removal and installation instructions start on page 9A-60 in the steering section.
http://wildaboutcarsonline.com/index.html
starfire
Dec 9, 2021 08:21 PM
shamusj
Apr 27, 2021 05:45 AM
317Cutty
Jun 18, 2014 10:53 AM
ros6872
Mar 28, 2014 09:48 AM
oddball
Mar 4, 2014 06:42 AM
