Trunk Latch Return Spring Broken
Old Feb 10, 2023 | 01:46 PM
Toms cutlass's Avatar
The return spring inside the trunk latch is broken. (See example image.) The round torsion spring retains the latch when in the closed / locked position. Anyone have experience replacing the round spring inside the latch? Looks as if the 2 rivets holding the two halves together could be drilled out and replaced with bolts. Is the spring inside the manual trunk lock the same as in the electric trunk release? Trying to save an electric trunk release for '70 - '72 A-body. Thanks.
acavagnaro
Body work
Oct 24, 2019 10:19 AM
DoubleU30
Sep 14, 2018 05:24 AM
O-dawg
Feb 9, 2017 10:41 PM
delta fog
Feb 10, 2014 07:10 PM
mont1le
Feb 14, 2010 07:35 PM
