69 Cutlass headlights knob
Old Jan 23, 2023 | 01:02 PM
lala5818's Avatar
69 Cutlass headlights ****
My American Autowire kit came with a new headlight switch. I’m supposed to use the old **** and bezel.
the old **** won’t stay on and there’s no way to attach it without glue.
am I missing something? If I glue it I’ll have to saw it off if I ever need to change out the switch?
Old Jan 23, 2023 | 01:41 PM
69455's Avatar
Take a plastic grocery bag tear small pcs, put over shaft and push on ****.
Or re stake shaft to fit
Old Jan 24, 2023 | 06:09 AM
Just get a new **** and shaft assembly. They aren't that difficult to find.
Old Feb 18, 2023 | 09:06 PM
cjsdad's Avatar
Nobody else mentioned this so I will point out the obvious. To remove the **** and shaft, you pull the **** out like turning on the lights (battery disconnected) then press the small button on the top of the actual switch. This will release the shaft so it can be fully removed. Unscrew the retaining nut to remove the switch and reverse everything to put it back together. No need to saw anything off.
Old Feb 19, 2023 | 04:49 AM
As stated by cjsdad, the **** and shaft come out as a unit. Just glue it on.
rket56
May 31, 2021 04:09 PM
Tom Bilse
Sep 26, 2018 05:02 PM
442murdock
Dec 12, 2015 11:16 AM
Eaglesfan
Aug 8, 2014 05:14 AM
69-Sguy
Mar 3, 2007 01:30 PM
