1971 W-30 Fuel Pump
Old Mar 23, 2022 | 08:44 AM
h/o guy's Avatar
1971 W-30 Fuel Pump
Hi All,
I am looking for the correct, two-line mechanical fuel pump for my 71' W-30. If someone has the Carter or Airtex or other brand name part number that is still currently available, it would be appreciated.
The pump listed on the InLine Tube site is the correct design but according to them, whoever their supplier is has changed the design to the more standard three-line pump which obviously won't work.
Supercars Unlimited also lists the correct pump but they are having trouble right now processing and shipping orders and I need this pump asap to get the car back on the road.
Any assistance with this would be apprecaited.
Sincerely,
Grant
Old Mar 23, 2022 | 10:34 AM
The OEM number is 6470329. Airtex 41566 looks like the best fit, with 40 GPH at 5.25 - 6.5 psi. Unfortunately RockAuto, Amazon, etc all show unavailable. There's at least one on ebay right now.
Old Mar 23, 2022 | 10:39 AM
h/o guy's Avatar
Thank you for the info Joe.
Old Mar 23, 2022 | 11:06 AM
Will22's Avatar
https://www.thepartsplaceinc.com/pro...1-outlet/80087
https://www.oldsparts.com/product/fu...connections-2/
Old Mar 23, 2022 | 11:13 AM
h/o guy's Avatar
Thank you fr the additional info Will22
I am checking their inventory as we speak.
Old Mar 23, 2022 | 02:10 PM
My442's Avatar
Airtex 40736 is the HV version.
Old Mar 23, 2022 | 02:13 PM
h/o guy's Avatar
Thanks for the info My442
Old Mar 23, 2022 | 02:16 PM
For what it's worth, the data on RA says both are 40 GHP. When I go to the Airtex on line catalog, their data says 30 GPH for the 41566 but doesn't list any specs for the 40736.
Old Mar 23, 2022 | 02:25 PM
h/o guy's Avatar
Well, the 40736 obviously doesn't look like the original pump and has an evaporative return line port on it which W cars don't have..
Also, it would be questionable whether this pump would fit under the A/C bracket so I need to zero in on the Aitex 41566 I think for as close to original fit and apprearnce.
Old Mar 24, 2022 | 01:01 PM
joesw31's Avatar
Try carter M6108. There are several on eBay.
Old Mar 24, 2022 | 09:31 PM
I know for a fact the Airtex 40736 pump will clear the R4 compressor brackets on the G body cars. I bet the would clear the A6 brackets as well.
Old Oct 30, 2024 | 05:21 PM
mrb2872's Avatar
Related to this, can anyone share a picture of how they routed the fuel return out of the fuel filter? The views in the manuals don't explain much.
I curse the engineers whomever came up with that design. It was a mini-purgatory fiddling that thing together. My too short heater hose did not help the situation.
Thx.
carnutz
Mar 31, 2024 10:49 AM
scrappie
Sep 18, 2018 02:26 PM
Drbigblock
Jul 6, 2014 08:58 AM
Daverd
May 28, 2014 09:26 AM
JBrooks
Aug 14, 2010 05:56 PM
