64 power steering conversion
Old Feb 21, 2022 | 12:48 PM
Rob64cutlass's Avatar
Hey guys good afternoon, have a few projects at the moment going on my 64 soon as I button those up I will be looking to add power steering conversion to my stock manual steering set up. Looking to see if you guys can push me in the direction of some research to get that ball rolling. Any links to older threads or websites so I can educate myself a bit before going shopping. Also any suggestions on parts and pieces in the supplier world is also appreciated. Thanks in advance
Rob
Old Feb 21, 2022 | 01:09 PM
2blu442's Avatar
Here's an old thread, but you might read through it and see what you think.
What Steering Gearbox Can I Put In My 64?? - ClassicOldsmobile.com
Old Feb 21, 2022 | 01:14 PM
2blu442's Avatar
When you have time you might enjoy reading through this one too.
Update progress on 64 "Post" - ClassicOldsmobile.com
Old Feb 21, 2022 | 02:28 PM
Sugar Bear's Avatar
What is your goal, completely original or an upgrade?
I took mine from manual to PS over forty years ago, IIRC the pitman arm was different and I had to use the manual arm. Anyone know for sure?
Good luck!!!
Old Feb 21, 2022 | 07:30 PM
Charlie Jones's Avatar
Phantom Phixer
Good luck!!!
I'm going to assume this is an F-85 or cutlass.
Yes, the OP will need a power steering pitman arm.
There were two designs of pitman arm used in 1964. And the difference was in the diameter of the relay rod ( center link ).
He may need to change both the pitman arm and the relay rod
Old Feb 22, 2022 | 05:34 AM
The pitman arm is different because the shaft on the power box is larger than the one on the manual box. Be sure you get a pitman arm for an Olds. The Chevelles can vary.
Old Feb 24, 2022 | 08:22 PM
Good luck!!!
looking to upgrade...with the 455 already swapped in..., original is in the rear view. Looking to head in the resto mod direction.
Old Feb 24, 2022 | 08:26 PM
Yes correct I'm looking do a power steering upgrade on my 64 F-85 cutlass convertable. Thanks
Reese Neis
Jul 4, 2021 01:03 PM
edzolz
Apr 22, 2018 03:42 PM
My2nd 69 442
Mar 16, 2018 12:04 PM
painterbrad
Mar 24, 2017 12:10 PM
Mikep442
Suspension & Handling
Apr 7, 2014 06:15 PM
