1984 delta 88 royal brougham 307 v8
Old Oct 31, 2021 | 02:59 PM
Jamesdelta88's Avatar
88landyacht
I have a 84 delta 88 and the heat seem to go cold when the car is idling. When I start driving it heats up. But blows cold on idle. I have burped the rad and it still seems to blow cold. Any other suggestions ?
Old Oct 31, 2021 | 03:01 PM
88landyacht
I should also mention the blend door is shut so the outside air does not come in
Old Oct 31, 2021 | 03:05 PM
What thermostat is installed? What is the water temp? Is the recirculating valve open to the heater core?
Old Nov 2, 2021 | 05:39 AM
The blend door controls temperature. The recirculation door controls inside vs outside air. Which one are you talking about?
rml05
Mar 2, 2021 03:00 AM
WesternDevil
Dec 2, 2019 07:27 AM
ROCKET JO
Jan 29, 2009 05:46 AM
