Hose sizes and clip colors
Old May 5, 2021 | 04:34 PM
Adam Michael's Avatar
I was wondering what size rubber hoses are used for fuel lines, vapor lines and vacuum lines. I was also wondering what size hose goes over this brass fitting. And lastly what color spring clamps go where. Particularly on a 1972 4 barrel 350. I don't have the factory TCS Switch or quadrajet so a general idea of where they are suppose to go would be great. Thanks in advance!
Old May 7, 2021 | 04:01 PM
4speed455's Avatar
Vacuum lines are usually 5/32. Fuel line should be 3/8 feed and 5/16 return line. These are inside diameter measurements. I am also curious about where to find the correct size spring clamps for the fuel lines. Right now I have standard hardware store clamps and I would like to replace them with the correct spring clamps.
Old May 7, 2021 | 04:51 PM
Yellowstatue's Avatar
I found the correct fuel line clamps at the hardware store.
Old May 17, 2021 | 06:04 PM
4speed455's Avatar
Thanks for the tip. I also found the correct clamps at the local Ace hardware. The info I found said the 5/16 fuel line should use the black 9/16 clamps and the 3/8 fuel line should use the tan 5/8 clamps. On the 5/16 fuel line I found the black 9/16 clamps were too loose so I used the red 1/2 clamps. The tan 5/8 clamps did fit the 3/8 fuel line good though.
68RocketAction
Sep 16, 2019 05:03 PM
Oldssupreme
Sep 20, 2016 07:48 AM
88 Cutty Classic
Mar 7, 2016 11:50 AM
Cutlass455
Jun 6, 2015 03:29 AM
1983oldsmobiledelta
Dec 2, 2010 03:37 PM
