Another Air Cleaner
Old May 26, 2020 | 10:11 AM
spgosselin's Avatar
Another Air Cleaner
Any info known about this one would be amazing!
Old May 26, 2020 | 01:33 PM
2blu442's Avatar
This guy says its a 1966-67 Chevy car.
https://www.ebay.com/itm/1966-IMPALA...-/401599502099
Old May 26, 2020 | 04:54 PM
66SportCoupe's Avatar
Definitely 66 67 possibly 68 Chevy 4 bbl air cleaner
Old May 26, 2020 | 07:23 PM
cherokeepeople's Avatar
i would say 68.my 66 chevelle didn't have the hole for the heat tube off the ex manifold/
Old May 26, 2020 | 07:55 PM
69HO43's Avatar
I don't know Chevies too much.
GM parts book from October 1966 shows the number 6423262 fitting 1967 Chevelle and El Camino 327 (exc. closed vent system) w/ Rochester carb.
The 6423263, one number up from that, fit the same cars but FOR the closed vent system w/Rochester carb).
This place says it's 66 327 Q-jet without smog or closed vent system. Needs to use the front tube oil fill breather cap.
https://www.classicmuscle.com/327-q-...ill-tube-27446
Old May 27, 2020 | 08:05 AM
second pic,bottom side of the snorkel,my 66 396 car did not have that hole.and my sister had a 66 impala with 275 h.p. 327 and it did not have a hole either.could be california only.
Old May 27, 2020 | 09:50 AM
69HO43's Avatar
That's probably why the parts book showed it fitting 67 chevelle and el camino 327 only without the closed vent system. Maybe that's why it has a hole in it? I'm betting the part number on your 396 is different, too.
spgosselin
Feb 8, 2021 09:23 AM
spgosselin
May 26, 2020 10:48 AM
spgosselin
May 26, 2020 10:09 AM
oldaman
Jan 6, 2020 10:36 AM
scrappie
Apr 10, 2019 05:47 PM
