1970 Cutlass Fuel Tank Vent Hoses
Old Mar 17, 2020 | 03:15 PM
Cutlassfarmer's Avatar
I had to drop the fuel tank on my 1970 Cutlass Supreme to replace sending unit. The sending unit being replaced has 2 fuel lines coming from it. The question I have is what are the 2 fuel tank vent hoses coming from corner of tank supposed to be connected to? Both were just open not connected to anything. I expect some pollution item was removed. Should these be capped or what should I do? Having these hoses open does not seem like a good idea.
Old Mar 17, 2020 | 04:00 PM
2blu442's Avatar
Its a plastic vent that has the two hoses connected to it and something like cotton inside it. There should be a tab on the underside of the trunk floor that holds this vent in place.
Old Mar 17, 2020 | 04:09 PM
2blu442's Avatar
The reproduction companies have them, but it should look like this:
Old Mar 17, 2020 | 04:21 PM
Yellowstatue's Avatar
There wont be cotton in there, it will be foam to act as a filter.
Old Mar 17, 2020 | 05:10 PM
Thanks for all the help. That is exactly what I need. Just looked again. I see the bracket and I have a dried out piece of plastic in the tubes
Old Mar 18, 2020 | 05:09 PM
Toms cutlass's Avatar
Interesting, my '70 fuel sender has only 1 tube - fuel line only. Primitive by today's standards, emission control (fuel vapor return line) must have been added in later 1970 production. I thought this didn't occur until 1971.
Old Mar 19, 2020 | 03:09 PM
A '68 442 will have two lines on the sender. A '68 Cutlass will only have one line. Probably the same for '70 as well.
Old Mar 19, 2020 | 03:32 PM
The OP has a 1970 Cutlass Supreme with 2 lines on the sender. I have a 1970 Cutlass Supreme with 1 line on the sender.
Old Mar 19, 2020 | 06:15 PM
Maybe his car has or had a 455, big block with fuel return line, small block with no return line.
Old May 26, 2020 | 12:54 PM
70CutlassConv's Avatar
Does anyone know if this filter needs replaced from time to time? I just tried to fill up my car and gas kept coughing back out of the tank. My filter is about 10 years old
Old May 26, 2020 | 01:04 PM
VC455's Avatar
Barely Registered
Originally Posted by Toms cutlass
...emission control (fuel vapor return line) must have been added in later 1970 production. I thought this didn't occur until 1971.
The vapor canister was required on cars delivered to California dealers on and after Jan 1 1970 and the rest of the country had the requirement for 1971 model production.
Old May 26, 2020 | 01:37 PM
My build date is August 1969, early '70 production model year.
Old May 26, 2020 | 01:45 PM
It's a vent or air breather tube, with a cotton-like wad inside the plastic tube. Allows the gas tank to fill and drain easier, like a hole in the opposite side of a can for easier pouring. The '70 OE gas cap is non-vented. My '50-year old vent tube was not clogged, but I'm replacing it with a new tank. I can't imagine yours being clogged in just 10 years, unless perhaps you're in a very dusty climate and you drive a lot. It's tucked up way underneath so it's not likely to get plugged by dirt. Can you get under your car, remove and inspect it? Is it possible the gas nozzle at the gas station was simply pumping more volume than your tank could accept?
Edit: The neck of the tank does have a metal catch inside to hold the pump nozzle which can restrict the flow of pumped gas.
tgilligan
Sep 11, 2014 08:19 AM
HitTheHole
Aug 30, 2014 03:59 PM
CQR
Jun 22, 2012 06:25 AM
72 Olds Project
Oct 17, 2011 06:13 PM
glord
Jul 21, 2009 11:23 PM
