Fuel tank/evap canister question.
Old Jun 22, 2012 | 05:32 AM
CQR's Avatar
CQR
Need a little help here.
On my 67-442, the PO installed a new fuel tank and capped off the 2 nipples on the rear of the tank to the drivers side of the filler neck. I have installed a non vented cap to try to reduce the fuel smell in the garage. All that has done is caused the tank to collapse when the car cools off.
I'm thinking of installing a simple canister system and am wondering if I can use one of the capped off nipples as a vent? are they high enough in the tank not to allow liquid fuel to be pushed into the canister? Has anyone done this with good results?
Old Jun 22, 2012 | 06:08 AM
The capped-off nipples ARE vents (well, were SUPPOSED to be vents). Vent the tank properly. Adding an evap canister requires a carb with the proper ported vacuum source to periodically vent the canister.
Old Jun 22, 2012 | 06:25 AM
CQR's Avatar
CQR
Thanks Joe, I have a 1903 Edelbrock q-jet so t-eeing in to a ported source isn't a problem I think I'll give it a shot and see how much I can reduce the fuel smell.
costpenn
Dec 23, 2014 10:24 AM
The Bug Man
Jun 20, 2014 06:03 AM
Texas442
Jan 30, 2012 05:36 PM
Lady72nRob71
Jun 13, 2011 07:31 AM
xx69442
Nov 16, 2010 08:14 AM
