Fuel tank/evap canister question.
Need a little help here.
On my 67-442, the PO installed a new fuel tank and capped off the 2 nipples on the rear of the tank to the drivers side of the filler neck. I have installed a non vented cap to try to reduce the fuel smell in the garage. All that has done is caused the tank to collapse when the car cools off.
I'm thinking of installing a simple canister system and am wondering if I can use one of the capped off nipples as a vent? are they high enough in the tank not to allow liquid fuel to be pushed into the canister? Has anyone done this with good results?
costpenn
Dec 23, 2014 10:24 AM
Texas442
Jan 30, 2012 05:36 PM
