1968-1969 Cutlass blower-type rear window defogger
Old Mar 11, 2020 | 03:19 PM
p518's Avatar
In search of a wiring diagram for what is described in the above title. It uses a Lo-Off-Hi switch and not sure if a relay is required. Thanks in advance.
Old Mar 11, 2020 | 05:55 PM
If you have the switch, you can make a harness. The center terminal goes to the motor. The outer terminals are power. There is a jumper harness that goes inline with the brown wire to the fan switch The low speed has a coil of resistance wire, similar to what you would find on a points style ignition system. I got my re blower from a swap meet, the harness was cut up. Instead of using the coil or resistance wire, I used a 5 ohm 10 watt resistor from radio shack. I don’t know how close 5 ohms is to the original harness, but there is a noticeable difference between low and high. It works well, and has worked for 20 years.
Old Mar 12, 2020 | 05:30 AM
p518's Avatar
Thank you. This is very good, detailed information. Looks like you really have a handle on how to correctly wire this unit. I'll see what I can make happen.
Old Mar 12, 2020 | 05:34 AM
I don’t recall ever seeing a wiring diagram in the service manual. There is a few photos in the assembly manual showing the jumper harness.
tony442w31
Dec 6, 2015 10:18 AM
armycav0
Nov 1, 2014 09:10 PM
djd71355
Alero
Mar 11, 2014 11:09 AM
67-w30
Jul 15, 2013 06:08 PM
sammy
Feb 28, 2013 01:41 PM
